    Can't see textures outside the Edit comp. mode.....
    4 Posts 4 Posters 780 Views 4 Watching
    • gonashviliG Offline
      gonashvili
      Would like to see textures on entities outside the edit comp mode, is there a way to turn them on?
      THANKS
      HG
      • KrisidiousK Offline
        Krisidious
        kinda... Go to View>Component Edit> Uncheck hide rest of model. it will still be greyed out. but you can then use the dropper to sample other textures.
        By: Kristoff Rand
        • Wo3DanW Offline
          Wo3Dan
          @gonashvili said:
          Would like to see textures on entities outside the edit comp mode, is there a way to turn them on?...
          FAIK this isn't possible. You only get to see the shaded version of faces that are in a higher level. Nested entities further down in the editing context may be displayed as shaded with texture. But then you can consider them (these nested groups and components) to be in the editing contex, although a in lower level.
            Gerrit is correct. You can't see textures on faces outside of the current context when editing a component or group.
