    Graphics card- recognition
    6 Posts 3 Posters 656 Views 3 Watching
    • H Offline
      hublan
      Greetings
      in the opengl dialogue box , sketchuip doesnt offeror recognize my nvidia graphics card only the standard intel card. How do I change the default so that I may select a different option in the capabilities section. Thank you in advance for your assistance
      Jeff
        Do you have more than one graphics card installed in your computer?
          Go to your nvidia settings and make sure that you assign the nvidia card to SketchUp. By default, it is set to use the Intel card.
          (I have some screenshots somewhere - I'll try to find them for you if needed)
          OK, here they are. Note that my system is Hungarian but hopefully the screenshots and markup still help.
          Computer settings > Hardware and sound
          https://lh4.googleusercontent.com/-Hk7Y6RJIAfA/TpKkv7GQIOI/AAAAAAAAGto/EgCMXWHWBxM/s855/Acer-02.jpg
          nvidia control panel
          https://lh6.googleusercontent.com/-ou5QouXzSkA/TpKkvDGt0LI/AAAAAAAAGtk/VaUGmnqYHPk/s855/Acer-01.jpg
          3D settings > Global settings tab: Here you can set the nvidia card globally
          https://lh6.googleusercontent.com/-lrBPbU8SWW0/TpKkwT-tZ2I/AAAAAAAAGts/vzA6E9_q4gM/s920/Acer-03.jpg
          Program specific settings (tab): here you can set it to certain applications (like SketchUp) only
          https://lh3.googleusercontent.com/-CQU3HShpBUw/TpKkw3ei0fI/AAAAAAAAGtw/Bk9KrJ1yvKw/s915/Acer-04.jpg
          • H Offline
            hublan
            Gaieus_ thank you so much for your quick reply to my question. I followed the steps that you suggested however in the gl settings under capabilities the intel card is the only option presented. I have made the nvidia card the global default. Thanks again, I appreciate your efforts to answer my question
            jeff
            • H Offline
              hublan
              Hi Dave- yes there is an intel card and an nvidia card installed on my laptop.
              jeff
                jeff
                Yes, these newer laptops come shipped this way. It's good to have the Intel card for less graphic hungry apps.
                πŸ‘
