    Lateral distorsion
    renderpluginsextensions
    4 Posts 2 Posters 434 Views 2 Watching
    • sketcpeppe75S Offline
      sketcpeppe75
      I wanted to ask a little help ... I rendered with v-ray .... how do I prevent the rendering appears distorted on the sides? I have a right and a lengthening contraction on the left! Is this normal? I have this in perspective when an object is closer (eg columns, the column in front is bigger) but the arms are at the same distance! hello
      P.S. an opinion on the rendering! I'm new. I have problems with the interior lights. I inserted a rectangular light beams with intensities below 25 (and you can see the solid line) and increased the value of gi to 10 images otherwise I "grainy." some trick to internal? hello πŸ˜„
      • V Offline
        valerostudio
        This distortion is a product of a wide field of view I assume. What's for FOV set to? As for lighting... I would suggest looking into LWF (Linear Workflow). There are a bunch of great tutorials on the web about this.
        Here is a good starthttp://www.davidfleet.com/tutorials/linear-workflow
          sketcpeppe75
          I thank you for prompt response ... regarding the fov, being small rooms, I set the value 50 ... . otherwise I could not see anything. for example I have a bath of 7-8 square meters! unless render in plan, the result is always this! 😞 OK. ... I think I still have to do a lot of practice! Thank you very much
            sketcpeppe75
            I think, however, that even with the default fov 35, the problem is the same
