    SU8 Paid Display Prob
    10 Posts 5 Posters 565 Views 5 Watching
      seasdes
      I imported a 3D model from Datacad into SU8. The model has a 'sheen' to it. When I add to the model the new stuff displays OK.
      What do I need to do to the imported model to remove the 'sheen'?
      Screen clip attached.
      Walter
      Using Sketchup Pro 2019
      • jeff hammondJ Offline
        jeff hammond
        upload the .skp model with the bad shading..
        dotdotdot
        • Chris FullmerC Offline
          Yeah, please supply the model. Looks like there's going to be a tiny line segment that has been smoothed. That is one reason that can happen.
          All my Plugins I've written
          • KrisidiousK Offline
            Krisidious
            triple click on the model once you're inside of the group or component. then use the soften edges menu bar to unsoften everything. You may also need to triple click the geometry and unhide everything.
            By: Kristoff Rand
              seasdes
              Attached is the file
              Walter
              test1.skp
                Krisidious
                Fixed in the manner I explained. also i purged all the excess stuff by running the purge unused command. from 2 megs to a few hundred kilobytes.
                test1.skp
                By: Kristoff Rand
                  seasdes
                  Thanks so much for your help.
                  Regards
                  Walter
                    Krisidious
                    No problem... Our pleasure.
                    By: Kristoff Rand
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi Walter, hi folks.
                      I also unsoftened all edges in all the groups of your model and it looks good.
                      I spotted a few things that may cause problems at a later stage. See this SU file for ideas.
                      test1 - JL.skp
                        seasdes
                        Thanks Jean
                        Walter
