    Dimensions error
    12 Posts 3 Posters 1.7k Views 3 Watching
    • A
      Aarhus8000
      I recently upgraded to the latest Trimble release of SketchUp for Mac 8.0.16845 and I'm starting to see a problem I've never seen before.
      The dimensions I place inside a model will change in measure and randomly disappear. In the attached example I place a dimensions indicator within two blocks 600 mm apart. I then took a copy of the right block and rotated it 90 degrees and now when I change the height of the rotated block the dimensions between the two original blocks change accordingly... Is this normal?? I've never notices this before and I've done similar operations many times before in earlier versions of SU.
      Please see attached. Thanks.
      • Kristian
      • Wo3DanW
        Wo3Dan
        Could you please attach the model itself?
        It's not quite clear to which endpoint (or invisible intersection) the right side of the 600mm dimension is associated. The red axis might be "blocking" something here that may be relevant.
        • A
          Aarhus8000
          This is very strange.... I think it's a bug. I opened the file and reproduced the error. Then when I pressed Cmd+S to save the dimensions in the model disappeared...(??). If I close the file and open it again I can see that the changes are saved but the dimensions are gone.
          Also, the 600 mm are referenced from the two inside corners but look what happens when I double-click the face of the block to the right:
          There's no hidden geometry in the file and I've tried copying the visible geometry to a new document.
          Dimensions.skp
          • A
            Aarhus8000
            Could someone try a test please??
            1. Open the attached file 'Dimensions CORRUPT'.
            2. Mark the dimensions between the two inside corners (see attached file 'Screen 1').
            3. Pull the dimensions out from the model.
            4. Switch to the select tool.
            5. Double-click the visible face of the left side block (see attached 'Screen 1').
            Do you then see the same as in the attached file named 'Screen 2'??? I have no idea where this second dimensions listing is coming from but I can reproduce the error over and over again in the file called 'Dimensions CORRUPT'.
            Thanks.
            Dimensions CORRUPT.skp
            • D
              driven
              both files seem ok on my mac, with only a few plugins.
              do you have driving dimensions or other dimensions plugins?
              john
              • A
                Aarhus8000
                Thanks, John.
                Nope, no plugins installed. Are you running the latest version of SU for Mac?
                • D
                  driven
                  yeh, latest.
                  try copy/pasting into a new drawing and see if the problem travels. I can't reproduce it here, very odd.
                  john
                  • A
                    Aarhus8000
                    Yep, it seems to travel to some extent. I pasted the geometry into a blank document but now when I double-click the same face the "bug" is reproduced differently - this time on the right side of the original geometry....(????). Very strange....
                    • D
                      driven
                      In the second drawing, open material browser and try to delete the grey material used by dimensions, it should delete, unless in use... if it won't try changing it to lime and see what happens...
                      john
                      • A
                        Aarhus8000
                        If I replace the color used by dimensions the error still reproduce - just now with dimensions in a new color.
                        • Wo3DanW
                          Wo3Dan
                          @aarhus8000 said:
                          Could someone try a test please??...
                          I tested both files in SU8 windows version and couldn't find anything wrong either.
                          Have you checked what happens when applying: Model Info > Statistics > Fix Problems? Any signs?
                          • A
                            Aarhus8000
                            Actually this check did find errors! I had run the test earlier just after opening the file and it didn't find anything but if I reproduce the error and then run the test then this is found:
                            If I now try and reproduce the error it is gone so this fix did the trick. Wonder why it happened and what it means??
                            Thanks!
