    Making solid 3 intersecting curves
    7 Posts 4 Posters 368 Views 4 Watching
    • jacbk612J Offline
      jacbk612
      Hi, not sure if this is a newbie question but I am trying to model an acoustic guitar and have much of it done. However I am hung up on how to do the 3 intersecting curves that form the bottom of the neck on the guitar. I have included a picture. I have tried Fredo's curviloft but the results are not what is required.
      Thanks,
      Jacques
      assuming the guitar is lying flat on the large flat bottom face, the 1st curve surface is on the neck and in the vertical plane and is an arc, the next surface is on the guitar body in the vertical plane and is a curved rectangle, the last surface is in the horizontal plane and is an extended arc shape
      • gillesG Offline
        gilles
        Have a look at this file for ideas.
        All plugins used can be found in Plugins index
        http://sketchucation.com/forums/viewtopic.php?p=250026
        Guitar-heroe.skp
        • gillesG Offline
          gilles
          OUpS! J'oublie souvent. 💚
          @Pilou: il faudrait nous pondre un plugin qui enregistre automatiquement en V6 💚 💚 💚
          Guitar-heroe_V6.skp
          • pbacotP Offline
            This is done with Curviloft skinning on 1/2 the profiles. Would that work for you?
            I just drew some arcs. I know they aren't the exact curves. I see that you are looking for the actual block piece and not the full transitional shape to the straight part of the neck, but you could cut it afterward.
            • TIGT Online
              Jim wrote a plugin that saves as the previous version - it just needs a tweak to do two steps back...
              Jim a écrit un plugin qui permet d'économiser de la version précédente - il a juste besoin d'un tweak de faire deux pas en arrière ...
              • gillesG Offline
                gilles
                Windows only....
                • jacbk612J Offline
                  jacbk612
                  Wow! Yes, thank you very much.
                  Jacques
