    Decreasing Polycount, I guess
    4 Posts 3 Posters 252 Views 3 Watching
    • F
      Futurepast
      I created a simple pipe but with alot of holes in it. It has SO MANY hidden lines it takes forever to do anything... click and wait and wait. Is there a way to convert to a lower count even if the drawing is alittle "rougher"?
        Might be easier to give a good answer if you could share at least an image if not the SKP file. Nonetheless, if it is a simple pipe as you say, it might be easier to start over. Begin with circles with fewer sides.
        • KrisidiousK
          Krisidious
          Thom Thom's cleanup tools do a great job of reducing model size and optimizing.
          http://sketchucation.com/forums/viewtopic.php?t=22920
          By: Kristoff Rand
          • F
            Futurepast
            Thanks, I started over doing it a different way and the poly count went way down. The first time I did a screen layout for the holes and then used radial bending to make the pipe shape. I thought it would be easier to use a grid pattern first. It was the bending that added the extras. This time I just made the pipe and took the time to punch the holes. More time less problems πŸ˜„
