    Bicycle cog plugin?
    7 Posts 4 Posters 966 Views 4 Watching
    • N
      nickinwv
      Does anyone have a plugin or other resources to make it easier to make bike cogs and chainrings? I'm working on an invention and I don't want to have to make the cogs from scratch. In fact if there are cassette cogs and a freehub spline somewhere I would prefer to just use those. Couldn't find any in the 3D warehouse, just a 6sp freewheel.
        Maybe this or the one here would get you going?
        • N
          nickinwv
          Dave, thanks for the links but those are for meshing gears. I'm looking for something for chain cogs, which have a different profile. I found a link to a geometric construction technique
          http://www.gizmology.net/sprockets.htm
          but I was just wondering if anyone had created a plugin that does the same thing.
            I know they aren't for the same sort of gears but they're the only plugins I know of for drawing gears. If you can get the correct tooth profile, drawing them from scratch shouldn't be that hard.
            • gillesG
              gilles
              Dave is right, from scratch and make a library of components.
              Also for chain look at Chris Fullmer's component stringer in plugin index.
                Drawing the sprockets from scratch shouldn't be that hard if you have the dimensions and other specs. I drew accurate sprockets and the roller chain for this bench vise by hand and it didn't take all that long.
                Both are made up of a bunch of pretty simple components.
                • D
                  driven
                  not a plugin but a tutorial
                  http://sketchucation.com/forums/viewtopic.php?f=15&t=38131&hilit=+bicycle#p336850
                  they can be quite easy once you get the hang of it...
                  john
