    [Request for Plugin] Safety Railings
    5 Posts 4 Posters 483 Views 4 Watching
    • Bob JamesB
      Bob James
      Much of my work involves design and modification of facilities in which there are safety railings at edges, around cut-outs up stairs/slopes.
      They are of varied kinds (see attachment):
      • Contiguous – straight
        • Contiguous – multiple directions
        • Curved
        • Round corners with and without separate connectors
        • Sharp corners
        • With and without lower flat safety toe plate
        • Painted Brushed aluminum
        • Combined horizontal and slanted (for stairs)
          It would be very helpful if a plugin were available that would draw these railings based on input of:
      • Line(s): straight, arc, welded multi-directional straight, straight and sloped drawn in the model
        • Select the line
        • Open the plugin and select from the following options:
        • Tube diameter (2” or 2.5”, default = 2”)
        • Railing height (default = 36”) with intermediate railing at 1/2 the top railing height
        • Number of intermediate verticals (evenly spaced)
        • Sharp or round corners
        • With or without connectors
        • With or without toe-plate
        • Material: Brushed Aluminum or Dark Red
      Any Ruby guru interested? 🎉
      • sdmitchS
        sdmitch
        Bob, I started working on something like this last October.
        http://sketchucation.com/forums/viewtopic.php?f=323&t=48176&p=432239&hilit=handrail#p432239
        I see if I can adapt it to your specs.
        http://sdmitch.blogspot.com/
        • Bob JamesB
          Bob James
          Wahoo
          • J
            jonorman
            Ur working on my request???? :heart_eyes: Thank you sooooo much.. Im so greatful, looking forward to see... Thank you.. There`s a special place in in the "afterlife" for you pluginwriters that make our working days easier....
            • R
              rv1974
              could you please enable (in your following plugin) the following behavior for vertical elements:
              1. obligatorily: posts in the corners;
              2. the gaps between vertical elements (placed evenly between corner posts) have the value which is closest to defined by user <= in accordance to local regulations
