    [Request for Plugin] Safety Railings
    5 Posts 4 Posters 467 Views 4 Watching
    • Bob JamesB Offline
      Bob James
      Much of my work involves design and modification of facilities in which there are safety railings at edges, around cut-outs up stairs/slopes.
      They are of varied kinds (see attachment):
      • Contiguous – straight
        • Contiguous – multiple directions
        • Curved
        • Round corners with and without separate connectors
        • Sharp corners
        • With and without lower flat safety toe plate
        • Painted Brushed aluminum
        • Combined horizontal and slanted (for stairs)
          It would be very helpful if a plugin were available that would draw these railings based on input of:
      • Line(s): straight, arc, welded multi-directional straight, straight and sloped drawn in the model
        • Select the line
        • Open the plugin and select from the following options:
        • Tube diameter (2” or 2.5”, default = 2”)
        • Railing height (default = 36”) with intermediate railing at 1/2 the top railing height
        • Number of intermediate verticals (evenly spaced)
        • Sharp or round corners
        • With or without connectors
        • With or without toe-plate
        • Material: Brushed Aluminum or Dark Red
      Any Ruby guru interested? 🎉
      • sdmitchS Offline
        sdmitch
        Bob, I started working on something like this last October.
        404 Not Found
        (sketchucation.com)
        I see if I can adapt it to your specs.
        http://sdmitch.blogspot.com/
          Bob James
          Wahoo
            jonorman
            Ur working on my request???? :heart_eyes: Thank you sooooo much.. Im so greatful, looking forward to see... Thank you.. There`s a special place in in the "afterlife" for you pluginwriters that make our working days easier....
              rv1974
              404 Not Found
              (sketchucation.com)
              could you please enable (in your following plugin) the following behavior for vertical elements:
              1. obligatorily: posts in the corners;
              2. the gaps between vertical elements (placed evenly between corner posts) have the value which is closest to defined by user <= in accordance to local regulations
