    Faces that close but should not
    4 Posts 4 Posters 764 Views 4 Watching
    • Jean LemireJ
      Jean Lemire
      Hi folks.
      See this SU file. The text in the file explain the problem.
      Faces that close but should not close.skp
      I wonder what is causing the problem.
      Best regards.
      • A
        Aerilius
        That is interesting.
        It is not caused by any inaccuracies around SketchUp's tolerance (this is often a reason for weird behavior), all joining edge segments meet at [0.0, -20.1771653543307, 25.3818897637795].
        Actually it does not matter where you start the arc (at any end point of a planar loop of edges), it triggers SketchUp's automatic face closing function.
        • jeff hammondJ
          jeff hammond
          using a line doesn't trigger the behavior.. using the rectangle tool does..
          πŸ˜•
          dotdotdot
          • thomthomT
            πŸ˜•
            Maybe the tools, Arc and Rectangle, runs edge.find_faces on all connected edges instead of only on the newly added edges? Where the Line tool does it on all just the new edge.
            Just wildly guessing.
