    Refraction layer-no fog colour in final render
    renderpluginsextensions
    3 Posts 3 Posters 923 Views 3 Watching
    • E Offline
      edlux
      hello guys,
      i just started experimenting with refraction in glas material and water material...
      but i do not get in final render any fog color ,no matter how high fog color value is,or object thick is...
      here is my rendering .it should be a glass thin wall.glass ball and a pool of water.
      I am using vray sketchup 1.49.01...please help
      • andybotA Offline
        andybot
        your fog will depend on real-world scale, and having a closed volume. If your example above is really small compared to real life, fog will hardly show up, regardless of the settings. If you don't have proper front face/ back face orientation of your object, it will be incorrect too.
        • V Offline
          valerostudio
          A cheat if you just need color is to put the color directly on the refraction. you won't get the SSS effect but on box this may not matter much.
