    Drawing 2D Floorplan walls from lines
    24 Posts 9 Posters 8.0k Views 9 Watching
    • gascatG Offline
      gascat
      Thanks heaps Massimo....that works quite well.
      cheers...Wayne
      • massimoM Offline
        massimo Moderator
        You're welcome Wayne. πŸ˜„
        • Mike LuceyM Offline
          Mike Lucey
          ... maybe I am missing something here but if CAD drawings are available, would it not make sense to use PDF2CAD and bring them into SU, then clean up? Of course the PDF would have to be vector! Also I imagine the builder would be in a postion to obtain .dwg which would make more sense!
          (visual-integrity.com)
          • P Offline
            pier70
            No Mike, if u have alredy a dwg there is not problem but if u have a jpeg or a pdf, from an image, when u redraw, the line that u are drawing are not accurate, u must correct a lot
            and if u have some quote u can re draw the floor plan but I think SU is slow in this if I compare it to a cad.
            • 2 / 2
