    Turning a selection into a face?
    40 Posts 4 Posters 2.0k Views 4 Watching
      tomot
      the code snippet below asks the user to make a selection
      model=Sketchup.active_model
      	ents=model.active_entities
      	sel=model.selection
          if sel.empty?
            UI.messagebox("No selection !")
            return nil
      what code do I require to turn that selection into a face?
      _____________ == Sketchup::Face
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        There are many ways, e.g.
        sel.grep(Sketchup::Edge).each{|e|e.find_faces}
        adds all possible faces edges in the selection...
          tomot
          If I use the following statement:
          $newface1=sel.grep(Sketchup::Edge).each{|e|e.find_faces}
          the ruby console respond is:
          %(#FF0000)[$newface1
          I was expecting something like:
          #Sketchup::Face:0xb3cb350
          tomot
            That method doesn't return faces, it just makes them !
            To find them try...
            ` edges=sel.grep(Sketchup::Edge)
            ofaces=[]
            edges.each{|e|ofaces << e.faces}
            ofaces.flatten!
            ofaces.uniq!
            edges.each{|e|e.find_faces}
            nfaces=[]
            edges.each{|e|nfaces << e.faces}
            nfaces.flatten!
            nfaces.uniq!The array 'nfaces' is all of the faces that are now attached to the edges - old and new. To find just the new faces try... faces=nfaces-ofaces`
            Where 'faces' is the array of those...
              tomot
              I did not know that this is a 2 stage process, 1: find & 2: return
              $newface1=sel.grep(Sketchup;;Face) #finds face only!
              $newface1.pushpull $inset
              So How do I implement a pushpull of $newface1?
              tomot
                First off...
                Don't use $ variables !
                If the vars are spread across different methods in the same class/module use @.
                Otherwise why use them at all...
                Try
                newface1.pushpull(inset)
                or
                @newface1.pushpull(@inset)
                Depending on the +/-ve value of the face it dictates the extrusion relative to the face.normal.
                Note that the face.normal can be determined prior to the pushpull and then face.reverse! if it's the 'wrong orientation', for example you want the face to be 'down' so a +ve inset moves the pushpull down too then test face.normal.z<0, and if not you can use face.reverse! before the pushpull is done...
                  sel.grep(Sketchup::Face)
                  This returns an array of all faces in the colletion (in this case selection)
                  <span class="syntaxdefault"><br />faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;}<br /></span><span class="syntaxcomment">#&nbsp;Push/pull&nbsp;all&nbsp;faces<br /></span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">distance&nbsp;</span><span class="syntaxkeyword">)&nbsp;}<br />&nbsp;</span><span class="syntaxdefault"></span>
                  If you want only one entity, use find():
                  <span class="syntaxdefault"><br />face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;}<br /></span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">distance&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                    tomot
                    @tig said:
                    First off...
                    snip
                    I was using $ variables only to check what my face code was actually being selecting in the Ruby Console. I still trying to resolved this issue. 😢
                    tomot
                      tomot
                      <span class="syntaxdefault"><br />faces </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxcomment"># Push/pull all faces<br /></span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> distance </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault"></span>
                      <span class="syntaxdefault"><br />face </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">face</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> distance </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"></span>
                      That's precisely my problem in a larger nutshell 😄 , I'm trying to use RickW's offset.rb which draws a 2nd offset on the initial "sel" selected face. Since there now 2 faces I'm having difficulty selecting the offset face for pushpull that the offset.rb created, and NOT the initial "sel" selected face for pushpull. (I can post a pic if my description falls short)
                      tomot
                        Dan Rathbun
                        Please do not use that script AS IS. We need to put it on the Quarantine List.
                        It overrides the API Array#offset method, and adds methods to both API and Ruby Core base classes.
                        You can use ideas from the methods that do not change base classes (by re-writing them and putting them inside your own namespace.)
                        So... anyway Rick's offset method should have returned a reference to the added face, because it uses Entities#add_face()
                        To use that method inside youir OWN namespace, you need to pass a reference to the original face into the method, and replace all self references within the method to the reference name of the passed face argument.
                        Example 1 (The internals have not been changed much, but an undo operation has been added):
                        module Tomot
                          module SomePlugin
                            class << self
                              def offset_a_face( face, dist )
                                unless face.is_a?(Sketchup;;Face)
                                  fail(TypeError,"Sketchup;;Face instance expected for 1st argument",caller)
                                unless dist.is_a?(Numeric)
                                  fail(TypeError,"Numeric subclass expected for 2nd argument",caller)
                                else
                                  if dist.zero?
                                    unless $VERBOSE.nil?
                                      puts("Tomot;;SomePlugin;WARNING; offset_a_face(); Offset distance was zero.")
                                    return nil
                                new_face = nil # this method's return value
                                pi = Math;;PI
                                verts = face.outer_loop.vertices
                                pts   = []
                                # CREATE ARRAY pts OF OFFSET POINTS FROM FACE
                                0.upto(verts.length-1) do |a|
                                  vec1 = (verts[a].position-verts[a-(verts.length-1)].position).normalize
                                  vec2 = (verts[a].position-verts[a-1].position).normalize
                                  vec3 = (vec1+vec2).normalize
                                  if vec3.valid?
                                    ang = vec1.angle_between(vec2)/2
                                    ang = pi/2 if vec1.parallel?(vec2)
                                    vec3.length = dist/Math;;sin(ang)
                                    t = Geom;;Transformation.new(vec3)
                                    if pts.length > 0
                                      vec4 = pts.last.vector_to(verts[a].position.transform(t))
                                      if vec4.valid?
                                        unless (vec2.parallel?(vec4))
                                          t = Geom;;Transformation.new(vec3.reverse)
                                    pts.push(verts[a].position.transform(t))
                                # CHECK FOR DUPLICATE POINTS IN pts ARRAY
                                duplicates = []
                                pts.each_index do |a|
                                  pts.each_index do |b|
                                    next if b==a
                                    duplicates<<b if pts[a]===pts[b]
                                  break if a==pts.length-1
                                duplicates.reverse.each{|a| pts.delete(pts[a])}
                                # CREATE FACE FROM POINTS IN pts ARRAY
                                if pts.length > 2
                                  begin
                                    if Sketchup.version.to_i > 6
                                      face.model.start_operation('Offset Face',true)
                                    else
                                      face.model.start_operation('Offset Face')
                                      new_face = face.parent.entities.add_face(pts)
                                    face.model.commit_operation()
                                  rescue
                                    face.model.abort_operation()
                                    raise() # to outer rescue clause
                                  end # begin
                                end # if
                              rescue TypeError
                                raise() # just re-raise the Exception
                              rescue => e # any other Exceptions;
                                  puts("Tomot;;SomePlugin;WARNING; offset_a_face(); #{face.inspect} did not offset; #{pts}")
                                  puts("Error; #<#{e.class.name}; #{e.message}>")
                                  puts(e.backtrace) if $VERBOSE
                                raise() # re-raise to any debugger in use
                              else # when no errors;
                                return new_face
                              end # offset_a_face()
                            end # proxy class
                          end # module SomePlugin
                        end # module Tomot
                        I'm not here much anymore.
                          Dan Rathbun
                          Example 2 : Here is a shorter edition that uses a vector or an array as the 2nd argument, and leverages the API's built-in Geom::Point3d#offset! method.
                          You can create a vector to pass as the 2nd argument, or call the method with an array literal, to say, offset the face by 10 units in the positive Z direction:
                          offset_a_face( @face, [0,0,10.0] )
                          module Tomot
                            module SomePlugin
                              class << self
                                def offset_a_face( face, vect )
                                  unless vect.is_a?(Geom;;Vector3d) || vect.is_a?(Array)
                                    fail(TypeError,"Geom;;Vector3d or Array expected for 2nd argument",caller)
                                  else
                                    vect = Geom;;Vector3d.new(*vect) if vect.is_a?(Array)
                                    if vect.length.zero?
                                        puts("Tomot;;SomePlugin;WARNING; offset_a_face(); Offset vector length was zero.")
                                      return nil
                                  verts = face.vertices
                                  pts = verts.map {|v| v.position.offset!(vect) }
                                  if pts.length > 2
                                    begin
                                      else
                                    rescue
                                    end # begin
                                  end # if
                                rescue TypeError
                                  return new_face
                              end # proxy class
                          end # module Tomot
                            Dan Rathbun
                            Example 3 : a one-liner (with no error trapping, etc.)
                            Assume @vect is either an Array or a Geom::Vector3d instance:
                            @nface = @oface.parent.entities.add_face(@oface.vertices.map {|v| v.position.offset!(@vect) })
                              <span class="syntaxdefault"><br />model&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />entities&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />sel&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br /><br /></span><span class="syntaxcomment">#&nbsp;Grab&nbsp;a&nbsp;list&nbsp;of&nbsp;existing&nbsp;faces<br /></span><span class="syntaxdefault">original_faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)<br /><br /></span><span class="syntaxcomment">#&nbsp;First&nbsp;offset&nbsp;face<br /></span><span class="syntaxdefault">face&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">is_a</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;}<br /></span><span class="syntaxdefault">offset</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">face</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">20.mm&nbsp;</span><span class="syntaxkeyword">)&nbsp;</span><span class="syntaxcomment">#&nbsp;I&nbsp;don't&nbsp;know&nbsp;what&nbsp;the&nbsp;real&nbsp;method&nbsp;is&nbsp;there.<br /><br />#&nbsp;Then&nbsp;Push-pull&nbsp;inner&nbsp;face<br /></span><span class="syntaxdefault">faces&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Face</span><span class="syntaxkeyword">)&nbsp;-&nbsp;</span><span class="syntaxdefault">original_faces<br />inner_face_from_offset&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">faces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">first&nbsp;</span><span class="syntaxcomment">#&nbsp;*should*&nbsp;be&nbsp;just&nbsp;one&nbsp;face<br /></span><span class="syntaxdefault">inner_face_from_offset</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pushpull</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">500.mm&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                              Untested
                                Dan Rathbun
                                @thomthom said:
                                I don't know what the real method is there.
                                It was my Example 1 (above) but Rick's edition was an instance method added to the Sketchup::Face class. (I re-wrote it to pass the face instance into the method.)
                                As shown in my one-liner (Example 3) a method is not really even needed.
                                @oface is the old face in the selection.
                                The new face will be @nface, and then just do the push-pull on it.
                                  That just offsets in an direction - we're talking about offsetting in terms of what the Offset tool does.
                                    tomot
                                    Tig, thomthom and Dan, thanks for your input it will take me a few days to digest your input, and try putting your input into use.
                                    but thomthom is right, I'm looking for the statement that allows me to offset the face the offset.rb creates.
                                    I was hoping a simple Boolean expression in the API would have served a very useful purpose, in this particular instance. 😢
                                    tomot
                                      Dan Rathbun
                                      @tomot said:
                                      ... but thomthom is right, I'm looking for the statement that allows me to offset the face the offset.rb creates.
                                      OK... then first of all the Example 1 re-write of Rick's method mimics the native offset tool, and returns the newly created offset face.
                                      (Just ignore Examples 2 & 3, as I did not understand what was needed and may have misunderstood what Rick's code was doing.)
                                      If you wish to AGAIN apply an offset, pass the newly created face and a new offset distance (or whatever distance,) into the method a second time.
                                      If you wish to move it or something else ... do whatever by using the returned reference as needed.
                                      Here is test script wrapped as Tomot::Offset, that adds right-click mouse "Offset Face" commands to the popup menu, but differs in result from the native tool by setting the selection to the new face. (The native tool does not change the selection set.) It also uses an inputbox to get the distance, ... but in practice you would bypass that and your code would supply the needed distance value.
                                      module Tomot
                                        module Offset
                                          class << self
                                              else
                                                if dist.zero?
                                                    puts("Tomot;;Offset;WARNING; offset_a_face(); Offset distance was zero.")
                                                  return nil
                                              pi = Math;;PI
                                              pts   = []
                                                if vec3.valid?
                                                  if pts.length > 0
                                                    if vec4.valid?
                                              duplicates = []
                                                  next if b==a
                                              if pts.length > 2
                                                begin
                                                  else
                                                rescue
                                                end # begin
                                              end # if
                                            rescue TypeError
                                                puts("Tomot;;Offset;WARNING; offset_a_face(); #{face.inspect} did not offset; #{pts}")
                                              return new_face
                                            #{ get_dist(face)
                                            #  Prompts for a distance, then calls offset_a_face()
                                            #  If a new offset face is created, it will be set as
                                            #    a single object of the current model's selection.
                                            def get_dist(face)
                                              result = UI.inputbox(['Offset distance ;   '],[0],'Offset a Face')
                                              if result
                                                ret = offset_a_face(face,result[0])
                                                if ret
                                                  sel = Sketchup.active_model.selection
                                                  sel.clear
                                                  sel.add(ret)
                                                else
                                                  return nil
                                              else
                                                return nil
                                            end #}
                                          end # proxy class
                                          unless file_loaded?(File.basename(__FILE__))
                                            UI.add_context_menu_handler {|popup|
                                              unless Sketchup.active_model.selection.empty?
                                                if sel.single_object? && sel[0].is_a?(Sketchup;;Face)
                                                  face = sel[0]
                                                  popup.add_item('Offset Face',10) { get_dist(face) }
                                                else
                                                  face = sel.find {|o| o.is_a?(Sketchup;;Face) }
                                                  if face # (nil if no face was selected)
                                                    popup.add_item('Offset First Face',11) { get_dist(face) }
                                            file_loaded(File.basename(__FILE__))
                                        end # module Offset
                                      end # module Tomot
                                      Question to the room at large: Regarding line 137, which is faster for large selection sets ?
                                      face = sel.find {|o| o.is_a?(Sketchup::Face) }
                                      OR
                                      face = sel.grep(Sketchup::Face)[0]
                                      Keep in mind both need to be fololowed by a nil test conditional, viz:
                                      if face
                                        tomot
                                        Dan thanks for your code, however regarding your last piece of code.
                                        I'm unclear as to how to use it.
                                        If I save your code as as offset.rb and replace it with the original offset.rb then load it in the console, I get an error in the console when I right click on selected face.
                                        Is this the way you intended it to be used? Please explain further!
                                        and just to make sure, please see the attachment regarding the face in question.
                                        tomot
                                          Dan Rathbun
                                          YES, make a selection, then right-click the selection (or a single face,) and an inputbox should pop up to enter a distance.
                                          IF you get an error, it would help if you paste the error message into a post.
                                            tomot
                                            there is also no "offset" reference in the context menu
                                            tomot
                                            • 1 / 2
