    Turning a selection into a face?
    40 Posts 4 Posters 3.1k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      @Tomot ... you have no profile information showing.
      (1) What SketchUp version ?
      (2) What SketchUp edition (Free or Pro) ?
      (3) What Platform & Operating System ?
      Lastly... if you are using an old version that does not support the 2nd ordinal position argument for add_item(), then remove that argument, and the menu items will just be at the end of the popup menu.
      The popup menu items are really just for testing... you can directly call the methods just as the menu items do, and remove the popup menu code.
      The code is an example.
      I'm not here much anymore.
      • T
        tomot
        Pro, My bad its working, after update!
        my plugins
        tomot
        • Dan RathbunD
          Dan Rathbun
          You may also be interested in this from TIG:
          [Plugin] TIG-Smart_offset v2.1
          I have not tried it, so I do not know if it sets the new offset face as the selection.
          TIG ?
          • TIGT
            TIG ?
            The originally selected face remains selected, but it should 'return' an array of the new face[s] formed when run via code...
            • T
              tomot
              I would like to take offset 1 step further: namely allowing the selection of more than one face.
              I revised Dan's script and added a secondary Reveal offset to the menu. The Reveal menu item represents the depth of the reveal.
              The reason behind my initial interest in RickW's offset.rb was to use it to provide reveals
              of selected faces, using SketchUp, for proposed concrete faces, be they cast-in-place or precast.
              Dan correctly identified users selecting more than 1 face, before the offset professing occurs.
              I need a hint πŸŽ‰ so I can I change the code to allow selecting more than 1 face?
              The attached pic shows my added revised code, the revised code is also attached.
              offset.rb
              my plugins
              tomot
              • Dan RathbunD
                Dan Rathbun
                You should not really have that method.
                You should have written an additional method to do a multi-face offset.
                What do you want the selection to hold at the end of the multi-face offset ?
                (Also.. ALWAYS check if results from an inputbox, in case the user cancels the dialog.)
                • T
                  tomot
                  I wanted all selected faces to be offset and revealed
                  I was unaware that I would have to write a muiti-face offset routine 😞
                  my plugins
                  tomot
                  • T
                    tomot
                    TIG's ....TIG-Smart_offset.rb does a great job offsetting multiple faces. πŸŽ‰
                    I hope he does not mind me learning more about Ruby using his script.
                    I added the following highlighted code to his script incorporating a reveal option.
                    Unfortunately this added complexity causes faces which share a common edge not to work well, with the reveal option, when pushpull is used.
                    my plugins
                    tomot
                    • Dan RathbunD
                      Dan Rathbun
                      When you make a change like that.. you need to change the top level namespace from TIG to Tomot
                      .. also I do not understand your use of the word "reveal" (which means "to show" or "to make visible".)
                      Can you post an image from the model of the final result you wish to achieve ?
                      • TIGT
                        @Tomot
                        Yes, please use your own Tomot namespace to avoid confusion with my TIG one...
                        @Dan
                        A 'reveal' [noun not a verb] is an architectural term for the 'sides' of the hole into which something like a window will be fitted... The window's 'reveals' are typically just the two vertical sides of its opening, which are arranged at [or near] right-angles to the main wall-face; the top 'side' is called the 'head' and the bottom one the 'sill': the use of 'reveal' for all four is correct, but somewhat unspecific and perhaps brings to mind a simple 'recess' in a wall with nothing inserted into it [e.g. 'the four reveals of that recess']. So I think Tomot is using the term 'reveal' to refer to all of the new face-parts that are created perpendicular to the main face: which will only be true 'reveals' if the pushpull were 'inwards', forming a 'recess' with 'reveals'; if it were 'outwards' the new form makes an upstanding 'plateau', and so it will technically not have 'reveals', but just 'sides' [cliffs!]... πŸ˜’
                        • T
                          tomot
                          @tig said:
                          @Tomot
                          Yes, please use your own Tomot namespace to avoid confusion with mt TIG one...
                          TIG is right, If you were working in an architectural office and did not know what a reveal was, your peers would wonder how you got the job. 🀣
                          my plugins
                          tomot
                          • T
                            tomot
                            @tig said:
                            @Tomot
                            TIG, I'm simply looking a your script and adding additional functonality, naturally and without question this is your script. This might turnout to be a good architectural addition and I would hope you could add it to your list of accomplished rubies πŸ˜„
                            However as I already stated, while the Offset portion of the script has no problems, because the offset faces does not interfere with any adjoining face. The added "Reveal option" does have problems, because it introduces the problem of how "pushpull" can't effectively deal with push pulling shared faces. I recall there had been discussion about shared faces and pushpull but I could not find any solutions. 😒
                            my plugins
                            tomot
                            • Dan RathbunD
                              Dan Rathbun
                              Which, of course tells you correctly that I have not yet worked in architectural engineering. (Only mechanical, electrical, electronic and systems with a combination of those [ie, railway, vehicles, aircraft, and commercial broadcasting.])
                              • Dan RathbunD
                                Dan Rathbun
                                Referring to my previous code posting: HERE
                                To get multiple faces rather than the first face (which is not may not work, as the selection's order may not be returned in the order the user picked,) ...
                                      UI.add_context_menu_handler {|popup|
                                        unless Sketchup.active_model.selection.empty?
                                          sel = Sketchup.active_model.selection
                                          if sel.single_object? && sel[0].is_a?(Sketchup;;Face)
                                            face = sel[0]
                                            popup.add_item('Offset Face',10) { get_dist(face) }
                                          else
                                            faces = sel.grep(Sketchup;;Face)
                                            unless faces.empty? # (empty array if no face was selected)
                                              popup.add_item('Offset Selected Faces',11) {
                                                if get_values()
                                                  offset_multi_faces(faces)
                                The get_values() dialog method would need changing (from get_dist,) to just set the variables (as you did,) and return true to continue the command, or false if the user canceled the dialog, meaning they wished to cancel the command.
                                Then a new method offset_multi_faces(faces) would iterate the faces array, calling offset_a_face() for each face member in the array.
                                • TIGT
                                  My Smart_offset method should return an array of the face[s] made by the offset [excluding the original face], which in your example will be just the inner new rectangular face.
                                  So if you move the pushpull code into the block that is offsetting each face in turn to be something like:
                                  faces.each{|face|
                                    newfaces=TIG;;Smart_offset.new(face, @dist, tidy)
                                    newfaces.each{|newface|newface.pushpull(@reveal)}if newfaces
                                  it might work ???
                                  • T
                                    tomot
                                    That is an entire new can of worms!....I don't know how SU implements a user select all picking order. I also see different results each time I use select all If you copy and paste each of the 4 attached cubes and run the script on each of the 4 cubes separate, sometimes the script gets the reveal right, most of the time it does not.
                                    my plugins
                                    tomot
                                    • TIGT
                                      If you want to find the newly made reveal faces after the pushpull then here are the steps...
                                      Before you pushpull make an array of all active faces:
                                      facesIn=@model.active_entities.grep(Sketchup::Face)
                                      Now do the pushpull and then find all new faces....
                                      facesOut=@model.active_entities.grep(Sketchup::Face)-facesIn
                                      Next remove all faces that share the same normal as the original ' face'
                                      reveals=[]; facesOut.each{|f|reveals << f unless f.normal==face.normal}
                                      Now the array ' reveals' contains all of the new reveal-faces that were made by that pushpull...
                                      If there's a chance that the offsetting or pushpulling might delete the original ' face' then set norm=face.normal earlier in the code so that you have a record of it for use later on in ... f.normal==norm...
                                      • thomthomT
                                        Can be written as one statement:
                                        reveals = facesOut.select{ |f| f.normal != face.normal }
                                        • TIGT
                                          I know... but I thought it was a bit clearer what was happening the way I presented t πŸ˜’
                                          • T
                                            tomot
                                            With thanks again to the 3 Ruby Amigos πŸ˜„ I will work on implementing your suggestions this weekend.
                                            my plugins
                                            tomot
                                            • 2 / 2
