    Problem changing axis
    6 Posts 4 Posters 286 Views 4 Watching
    • hellnbakH Offline
      hellnbak
      When I try to change the axis of this component, I get this weird axis symbol, with a blue X where the blue axis line should be. Any suggestions?
      • pbacotP Offline
        These are the axes for a component set to "glue to". Change it in the component window under "edit" if you want.
        • hellnbakH Offline
          hellnbak
          Thanks, that did the trick. Can't imagine how it got that way, I have never glued anything.
          Wow, now I know almost a dozen things about SU πŸ˜„
          • gillesG Offline
            gilles
            It happen if you create a component on a face.
              Indeed. SU then assumes you want that component (or group as a matter of fact) to be glued later. Actually, it's the easiest way to create such components with the proper gluing plane from scratch.
              • hellnbakH Offline
                hellnbak
                Huh! I've created plenty of components on faces before, but since I don't have to change axis very often I guess I just never noticed this before.
                Good info, thanks πŸ‘
