    Ad Blocking on this website?
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    118 Posts 27 Posters 55.2k Views 27 Watching
    • N
      notareal
      I'd prefer hosts file to be clean and locked so that malware cannot change it. If you let any program to modify hosts... results can be surprising if you forgot it (or someone else uses computer that don't know that hosts file is modified). To protect hosts, you can take ownership of hosts. Then disable inheritance. Remove the modify permission from SYSTEM. Make sure you or even better a secondary administrator account only have full control on the file (don't mess with system if you don't know what to do).
      For blocking certain domain/ IP - use a firewall or some DNS proxy can be used, like http://sourceforge.net/projects/acrylic/, http://www.peerblock.com or similar... and naturally for name resolution better use DNS, like usually, not a relic "hosts" file.
      BTW Windows defender in Windows 8 may overwrite your hosts file entries, so better have also a firewall at "router level" on your network (keep in mind that NAT is not a firewall). If I have understood correctly in Windows 8 facebook.com and ad.doubleclick.net cannot be blocked by hosts file when defenter is used... might me more.
      • W
        winstonford
        If using AdBlock on Safari,
        goto preferences > extension > adblock
        check 'show me options..'
        goto customize
        paste below rule into the filter at the bottom and be sure to save:
        @@http://sketchucation.com/$document
        • TIGT
          goto customize
          Because SCF also links into 'buysellads.com' you'll probably also need to add that to your 'exceptions' list...
          • TIGT
            SketchUcation is free.
            BUT it has to be paid for...
            Servers etc all cost something.
            SCF receives a modest income from its discreet advertising banners: however, the advertisers need some comfort that their adds are at least visible to members.
            The 'terms of use' you agreed to when you became a member require you NOT to block advertising.
            To ensure that you are reminded of your promise, if you have an ad-blocker app on your browser that is set to block SCF's ads, then in reply SCF blocks your ability to see forum attachments [i.e. files and images]...
            So set your ad-block app to allow sketchucation.com AND buysellads.com [the latter is the company arranging the ads on SCF's behalf].
            try emptying your browser's cache too...
            If you still get missing attachments, then check your firewall settings also don't bar such things...
            If this also fails please let us know and we can try to come up with some more suggestions... ๐Ÿ˜’
            Many thousands of members successfully set up their connections to SCF without any difficulty, and then enjoy full access to all aspects of the forums...
            The SCF ad-banners are carefully selected and all relate to services and applications relevant to SketchUp - commercial-plugins, renderers, CAD, 3d-printing and so on... So they can be a useful source of information too...
            • jojo9J
              jojo9
              Since i came back to the restyled forum, i saw and see no more zip's nor images of other users postings. I'm good equipped with plugins so i have no particular needs for plugins to download, but it would be -it would be- very nice to look also at images, if user concepts aren't so implicit to understand.
              To adjust things, i tried to deactivate all me browser ad-blocking plugins, but nothing changed: Sketchucation continues to block me images and zips.
              ? which relationship exists between advertisements and users attachments ?
              it seems absurdly.
              • jojo9J
                jojo9
                Hi Tig and all other Moderators,
                to put it in the right direction:
                i've no problem with SCF ads. Really.
                But what i do to change my situation, nothing changes. I de-activated all my safari-plugins, have no firewall protection and cleaned my browser cache. Some service is yet running, protecting me from spam but http://buysellads.com and SCF is on the whitelist. What can i do?
                • TIGT
                  OK... can you post the exact 'whitelist' for sketchucation.com and buysellads.com ...
                  My ad-block entries are set like @@||sketchucation.com^$document etc...
                  Have you tried another browser like Chrome ?
                  • jojo9J
                    jojo9
                    not even Chrome changes displays me SCF attachments. So, it isn't the Browser to be the problem.
                    i added sketchucation.com and buysellads.com to my firewall whitelist, then i cleaned the Cache. Unfortunately, nothing changed.
                    • TIGT
                      Without access to your OS directly we have to guess here... ๐Ÿ˜•
                      Failing in Chrome at least suggests it's not a browser add-on.
                      Therefore it's either a firewall issue or perhaps some other app that you have running [like an anti-virus tool] that is blocking websites and therefore being interpreted by the SCF side as a deliberate ad-block...
                      Have you done this:
                      http://www.dummies.com/how-to/content/using-mac-os-xs-builtin-firewall.html
                      or
                      http://www.dummies.com/how-to/content/how-to-use-mac-os-x-snow-leopards-builtin-firewall.html
                      or
                      http://www.dummies.com/how-to/content/should-you-use-a-firewall-with-os-x-mountain-lion.html
                      http://www.ehow.com/info_12069970_tips-blocking-websites-mac.html
                      https://support.opendns.com/entries/22166860-Does-OpenDNS-unblock-ALL-subpages-on-a-site-if-it-s-whitelisted-
                      etc...
                      • G
                        Gรกbor
                        @jojo9 said:
                        May I ask if you're connected to the internet via a corporate network or not? If yes, is it possible that the corporate firewall blocks buysellads?
                        • Mike LuceyM
                          Mike Lucey
                          Thanks TIG for spending so much time trying to sort out this problem for jojo9. At least having it documented may save time for others in the same predicament.
                          • jojo9J
                            jojo9
                            i can't agree more as what Mike already said. I'm not the person who demands that somebody is jumping in for my requests right in the next moment, but ya.
                            I organized my web browsing settings long time ago, to live a half-way relative secure browsing experience. Nobody likes the man in glass, now lesser than yet before. (โ€ฆ) ๐Ÿ˜†
                            I forgot what i set up so carefully, but i modified several things, who aren't "standard" preventive methods, to block spam from the outside world.
                            Time to go back and study what i modified.
                            ๐Ÿค“
                            • Mike LuceyM
                              Mike Lucey
                              ๐Ÿค“
                              Or become a Premium Member and have the option of AB or not ๐Ÿ˜„
                              • Bryan KB
                                I'm getting the same message. Can't view posted images but see the ads just fine.
                                Using FF22,Vista and AT&T home and nothing has changed or been updated in the last 2 days.
                                Just tested with IE and same issue. Images loads and then disappears with Ad Block notice in its place.
                                Ad Block is turned off. All other software settings set to allow SCF.
                                No problems with other websites.
                                Something changed in the last 2 days.
                                • Bryan KB
                                  Now working again.
                                  How odd.
                                  Took Sketchucation off Ad Block whitelist and then reloaded and re-added it and it now seems to be working just fine.
                                  Things that make you go "hmmm".
                                    no, we are tweaking the site. so you're suggestion is just related to timing.
                                    toggling adblock doesn't fix it since we have it currently disabled
                                    • TIGT
                                      There were some IT gurus beavering away in the background at SCF this morning.
                                      Seems something got briefly broken giving false positives on the ad-blocking.
                                      It's fixed now... ๐Ÿ˜„
                                      • jojo9J
                                        jojo9
                                        Now i see users attachments again. Thanks for helping out.
                                        • 6
                                        • 6 / 6
