    Can't locate SketchyFFD inside sketchup
    4 Posts 3 Posters 1.3k Views 3 Watching
    • P
      Paul Crompton
      Was not sure whether to put this here or in plug ins but as I am a newbie it's here.
      I have downloaded the rb file for SketchyFFD and placed it in the plug in folder but I can not locate it anywhere in sketchup UI. Obviously I am doing something wrong as many people do use this plug in. I have the latest version of sketchup installed.
      Should there be a folder to go alongside this file? If so I am not sure where to find it.
      Any help will be appreciated - Paul
      • massimoM
        massimo Moderator
        Hi Paul, assuming that you have installed it correctly, FFD works with grouped geometry. You'll find it in the context menu: rigth click on a group-->FFD.
        • P
          Paul Crompton
          Thank you. I had tried everything but right click. Just need to practice with it now.
          Paul
          • M
            muhii
            thank You
            I can't believe I am benifiting something from 2013
            Reply Quote 2
