    Editing texture in application
    12 Posts 5 Posters 705 Views 5 Watching
      mwm5053
      While watching a video that thomthom did on quadface tool unwrap he edited a texture in Ps and save it, and it was updated in SU while I'm not using Ps but Pixelmator for Mac it doesn't seem to update Su for me. Is this a Ps thing or am I missing something here.
      http://www.youtube.com/watch?v=hnW_yjkM_SY it's about 4:00 in
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • jeff hammondJ Offline
        jeff hammond
        • in sketchup, go: Sketchup-> Preferences-> Applications.... make sure you have that set to pixelmator
        • apply a texture to a face in sketchup
        • go to 'colors in model' panel of sketchup's color picker
        • double click on the texture you'd like to edit
        • click button 'edit texture image in external editor'
        • the image will open in pixelmator
        • make your adjustments in pixelmator then save it
        • go back to sketchup and the image will update in the model
        dotdotdot
        • srxS Offline
          srx
          Maybe you did not set your image editor in Window/preferences/apllication
          www.saurus.rs
          • hellnbakH Offline
            hellnbak
            A simpler way is to just select any face that has the texture and click "edit texture image". At least that's the way I've always done it.
              mwm5053
              I did all of the above suggestions thanks by the way. Pixelmator wants to know where to save it, by default it wants to save it in MacHD/private/tmp so I let it didn't work, so I did it again and saved it in user/documents didn't work, I guess what I need to know is where to save it ?
              2011 iMac
              V2 Twilight
              • hellnbakH Offline
                hellnbak
                If it asks you where you want to save it, something's wrong, and it won't work. Are you clicking "Save" or "Save As"?
                  mwm5053
                  just save
                  2011 iMac
                  V2 Twilight
                    jeff hammond
                    fellas... he's on a mac -- these are windows things you guys are talking about...
                    pixelmator is weird in that it's trying to save the texture as a .pxm file (pixelmator's own file type.. similar to photoshop's .psd etc..)
                    so, when you're in pixelmator's save dialog, tick the box that says 'save copy as [png, jpg, or whatever format the texture happens to be.. the right choice will already be selected for you but it will vary depending on which type of texture you're using]
                    (then choose 'replace' at the prompt)
                    dotdotdot
                      mwm5053
                      Thanks Jeff that helps a lot will try it and get back
                      2011 iMac
                      V2 Twilight
                        mwm5053
                        Yep that worked Thanks again Jeff
                        2011 iMac
                        V2 Twilight
                          jeff hammond
                          dotdotdot
                          • P Offline
                            pedrinalex
                            Thank you Jeff.
                            I tray it in PhotoShop, and works very well
                            Pedro
                            MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
