    Convert projected texture from GE to not-projected?
    10 Posts 5 Posters 680 Views 5 Watching
      d12dozr
      The material on terrain imported from Google Earth comes in as a "projected" texture. Is there a way to convert the texture to be 'not-projected' without losing the UV mapping? I searched the Plugins Index, but didn't see anything that looks like it would work.
      The reason I ask is if I want to 3D print a color model from Shapeways, the material cannot be projected or else the sides of model get that smeared looking texture, like this:
      http://images.shapeways.com/model/picture/674x501_825059_702506_1355255796.jpg?key=ef1406b57007fe279dc9349b56af57a9
      http://goo.gl/f7ooYh
        If you do not project that texture, I am afraid it will be screwed and broken into as many segments as facets you have in the mesh. Why don't you paint the sides with some different material? (Well, probably there is a reason of course).
        One possible solution (have not tried yet): could you use TT's UV Toolkit plugin to copy the coordinates, un-project the image and then paste the co-ordinates again? (well, maybe this would paste them back projected of course but it may be worth fiddling around)
          Marcus, could you just apply a single color to the flat sides?
            d12dozr
            In the image above, I had painted the sides with a flat color but because the top image is projected the colors from the sides are removed when converting to VRML for color 3D printing.
            I'll try TT's UV toolkit...I forgot about that one.
            • cottyC Offline
              cotty
              Does this or this help?
              my SketchUp gallery
              • cottyC Offline
                cotty
                I think the mapping tool from SketchUV ($) can do it.
                my SketchUp gallery
                  d12dozr
                  UV Toolkit didn't work 😞 I guessing its because the terrain from GE isn't true Quadfaces.
                  Thanks for the links Cotty. SketchUV looks promising.
                    Aerilius
                    If you just want to remove the projected property, does it work to export to Collada and re-import?
                      d12dozr
                      Ooh, yes that did work. πŸ˜„ Now to see if the rest of the pipeline works...
                        πŸ‘
