    No tabs possible in text?
    7 Posts 6 Posters 483 Views 6 Watching
    • liquid98L
      liquid98
      I have a string = "t\tt"
      In console it prints:
      t		t
      But ents.add_text string, [0,0,0]
      Gives 'tt'
      why??
      Is there a magic workaround whose existence I'm not aware ? πŸ˜’ πŸ˜’
      Thnx guys!!
      Liquid
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
      • thomthomT
        hm.. I see the same thing. And I can't even add tabs to a Text entity using the native tool...
        • TIGT
          The 'newline' \n will work OK... BUT a \t doesn't.
          So you can't 'align' Sketchup's 2d Text using tabs.
          Tabs are rendered as 'empty characters'.
          You can of course replace any 'tabs' in the string with some spaces before using it - e.g.
          text.gsub!(/\t/,' ')
          for three spaces...
          Tab \t does work OK in the UI.messagebox methods.
          • fredo6F
            fredo6
            ...but it does not work in contextual menu texts, to right-align the short text. I think it was broken in v8.
            Fredo
            • Dan RathbunD
              Dan Rathbun
              By "short text" are you referring to accelerator keystrokes ??
              They are not supposed to be specified in the menu item text. The OS adds them to the menu item, after an accelerator is assigned to the UI::Command object, that is in turn assigned to the menu item.
              I'm not here much anymore.
              • D
                driven
                finally, something that actually works on a mac, but not on a PC?
                ` > tab=("t\tt")
                t t
                coordinates = [0, 0, 0]
                model = Sketchup.active_model
                entities = model.entities
                point = Geom::Point3d.new coordinates
                text = entities.add_text tab, point
                #Sketchup::Text:0x1c013cec`
                the screen text has the tab...
                john
                • liquid98L
                  liquid98
                  Thanks guys. It seems this is a PC only bug. So far no reason to buy a mac..
