    Maxwell: can't save image
    extensions
    4 Posts 3 Posters 1.2k Views 3 Watching
    • A
      Adorno
      Trying the demo of Maxwell, but the image can't be saved.
      No filetype can be chosen:
      http://s8.postimage.org/l23poz7ud/Indspilning_i_fuld_sk_rm_26_12_2012_191447.jpg
      And trying to save anyway, it says "specified directory does not exist" (tried many different ones):
      http://s8.postimage.org/sw4badfn9/Indspilning_i_fuld_sk_rm_26_12_2012_191457.jpg
      Anyone had this problem? Did a search and nothing came up; and the Maxwell forum is not very active.
      Sorry if this is not the place to ask.
      Windows 7, 64 bit.
      Maxwell v. 2.7.22
      SketchUp 8
      • jason_marantoJ
        jason_maranto
        You have to give it a file extension (".png", ".jpg", etc.).
        Best,
        Jason.
        • TIGT
          As well as specifying an image file-type [e.g. .png]... there's another major problem 😮
          You have a non-ASCII UTF-8 character in your user-name, which is then used in the file-path to your Desktop...
          This means that any part of a Sketchup Ruby tool that's checking for the existence of a folder or file will fail, simply because that version of Ruby can't process these characters [it's ASCII only I'm afraid!].
          This kind of error will occur in many Ruby-based tools should you choose your destination folder in a path containing any non-standard characters. Also never use non-standard characters in such file-names.
          Sorry... but you need to choose alternative 'clean' paths, OR change your user-name from 'Asbjørn' to 'Asbjorn'.
          Hopefully the next major update of the API will upgrade to a newer version of Ruby that is UTF-8 compliant in its 'File' operations...
          • A
            Adorno
            Whoah, I had no idea. It is indeed the letter Ø causing the problem. 😲
            Thank you very much.
