    Light areas in shadows
    23 Posts 5 Posters 882 Views 5 Watching
    • hellnbakH Offline
      hellnbak
      These areas should be in complete shadow, so why are the indicated areas light?
      • soloS Offline
        solo
        Is the ground a light colored material? may be a reflection.
        http://www.solos-art.com
        • hellnbakH Offline
          hellnbak
          Made the ground black, they're still there.
          • cottyC Offline
            cotty
            Is it a color or a texture?
            my SketchUp gallery
            • hellnbakH Offline
              hellnbak
              It's just a color
              • hellnbakH Offline
                hellnbak
                Well, I copied the door to a separate instance of SU, set shadows and model location the same, and the shadows look fine there.
                  jpalm32
                  Did you try tuning off the sun? Is the separate instance SU's sun set the same?
                  • hellnbakH Offline
                    hellnbak
                    Turning sun on or off has no effect. And yes, the shadow settings and model location are the same in both.
                      Make the back face color black or a very dark gray.
                      • hellnbakH Offline
                        hellnbak
                        I always make the reverse faces black.
                          How would we know? πŸ˜’ πŸ˜„
                          Have you checked to see that there's no face spanning the inside of the bumps? If there were and that face was unpainted, it might show through.
                            It sounds like you're out of luck.
                            Is the image you posted first a screen shot or an exported image?
                            • hellnbakH Offline
                              hellnbak
                              Yes, I've carefully checked the inside. No problems there.
                              • hellnbakH Offline
                                hellnbak
                                It's a screen shot
                                • hellnbakH Offline
                                  hellnbak
                                  I copied the door intending to upload it here to see if anybody could spot the problem, but of course the problem went away. And the model itself is too large.
                                  • hellnbakH Offline
                                    hellnbak
                                    What's the size limit on files attached here? I might be able to upload just part of the model where the problem is.
                                      The back face color isn't black in your last screen shot.
                                      • hellnbakH Offline
                                        hellnbak
                                        That's because it's a monochrome view. If I had used a non-monochrome view the back face would have been a black blob, and I was trying to show that the back face didn't have any problems that could cause the problem.
                                          Those are different things, though. Try changing the back face color from blue to black and see if you get a change in the behavior of those edges.
                                          • hellnbakH Offline
                                            hellnbak
                                            I don't see what difference it would make whether I paint the reverse faces black or whether I change them to black in Styles. The end result is the same, the reverse faces are black. They may look blue when using monochrome, but in fact they are black, just like the outside faces look white in monochrome, but in fact they are whatever color I painted the model.
                                            And no, changing them to black using Styles made no difference.
                                            • 1 / 2
