    Light areas in shadows
    23 Posts 5 Posters 1.0k Views 5 Watching
      Make the back face color black or a very dark gray.
      • hellnbakH Offline
        hellnbak
        I always make the reverse faces black.
          How would we know? πŸ˜’ πŸ˜„
          Have you checked to see that there's no face spanning the inside of the bumps? If there were and that face was unpainted, it might show through.
            It sounds like you're out of luck.
            Is the image you posted first a screen shot or an exported image?
            • hellnbakH Offline
              hellnbak
              Yes, I've carefully checked the inside. No problems there.
              • hellnbakH Offline
                hellnbak
                It's a screen shot
                • hellnbakH Offline
                  hellnbak
                  I copied the door intending to upload it here to see if anybody could spot the problem, but of course the problem went away. And the model itself is too large.
                  • hellnbakH Offline
                    hellnbak
                    What's the size limit on files attached here? I might be able to upload just part of the model where the problem is.
                      The back face color isn't black in your last screen shot.
                      • hellnbakH Offline
                        hellnbak
                        That's because it's a monochrome view. If I had used a non-monochrome view the back face would have been a black blob, and I was trying to show that the back face didn't have any problems that could cause the problem.
                          Those are different things, though. Try changing the back face color from blue to black and see if you get a change in the behavior of those edges.
                          • hellnbakH Offline
                            hellnbak
                            I don't see what difference it would make whether I paint the reverse faces black or whether I change them to black in Styles. The end result is the same, the reverse faces are black. They may look blue when using monochrome, but in fact they are black, just like the outside faces look white in monochrome, but in fact they are whatever color I painted the model.
                            And no, changing them to black using Styles made no difference.
                              Well, it was worth a try. You haven't found any other solution yet, have you? I was just trying to help. πŸ˜’
                              • hellnbakH Offline
                                hellnbak
                                Actually I phrased that badly. When changing the reverse faces to black in Styles, they are black only when viewed in monochrome. They are actually still whatever color you have painted them.
                                But I'm sure you know this.
                                • hellnbakH Offline
                                  hellnbak
                                  No, I've pretty much given up on this. Just adding another volume to my Sketchup ScrewUps collection, soon to be available in handsome leather-bound 7-volume sets at your local Barnes and Noble.
                                  I very much appreciate your help. Have a nice holiday.
