    Oceans and Seas in Sketchup?
    16 Posts 9 Posters 9.2k Views 9 Watching
    • Mistro11M Offline
      Mistro11
      I would like to create some water scenes like a lakeside or beach house but am at a loss as to how to go about setting up the water. In my last attempt, I made a terrain with TT's Bitmap2mesh and raised a rectangular plane where the water level would be. I then exported to Kerkythea and tried the various water materials from the water pack but none looked as realistic as I wanted. Though shaders and bump maps can be used, I would also like to model as much as possible to make the scene more convincing. I searched for any tutorials on making displacement maps for oceans but having a hard time finding a universal method that would cover most 3D render packages. I'm thinking if I can at least learn how to make a proper water displacement or bump map, I can apply it with the Bitmap2mesh to make a water plane within Sketchup and even make my own materials. Does anyone know of a good tutorial on this or is there a free program that can generate such maps like how the program "Wilbur" can generate terrain maps?
      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
      Structural Integrity is Not Just Physical...It's in the Design and Purpose
      • Chris FullmerC Offline
        I tend to think you'll get better results by doing the water as a flat plane and rendering it completely in a rendering software. If it didn't come out looking realistic enough.....do more tutorials. As for a universal solution, you pretty much described the basics of how it works. But remember that each software has its own process for wokring with materials, maps, etc. So a single universal solution there isn't.
        Want to post what you came up with? Maybe people here can help give some tips on how to make it more realistic?
        All my Plugins I've written
        • Mistro11M Offline
          Mistro11
          I think I'm on to something. πŸ€“
          I used ThomThom's Mesh from Heightmap plugin to make the terrain and the water mesh after making a greyscale bitmap in Photoshop.
          In Photoshop I created some displacement maps for the water by doing the following from the filters:
          1. Create clouds
          2. Create Noise
          3. Bas Relief
          4. Motion Blur
            I played around with the settings of each filter to get various effects and saved out of greyscale mode as a 8bit bitmap. Using TT's plugin I try to stay at 100 pixels and under. 50 pixels works just fine (see the calm water below).
          This is a result after doing the mesh to heightmap operation in sketchup. Works like a charm.
          This is a test render in Kerkythea. I assigned a glass material to the water mesh. This one would probably be better for an ocean scene. Not as realistic as I want but it's a start. This water mesh was created with a bitmap of 100x79 pixels
          This one is more like it but calm. It works. This mesh was created with a bitmap of 50x60 pixels
          I will experiment further to get some better water effects. I'm trying to get more radial waves but still trying to figure it out in PS.
          • N Offline
            notareal
            One important thing with Kerkythea - it does lack "Sun Pool Caustics". So water is a bit tricky to get realistic... one needs a way to fake caustics. Some underwater projector lights with suitable caustics bitmat might do the trick πŸ˜‰
            • irwanwrI Offline
              irwanwr
              nice water with Kerkythea πŸ˜„
                Or you can use something like this (there's also a free version if you do not mind that watermark)
                • pbacotP Offline
                  I think that's a very realistic SU solution.
                    Well, what you came up with sure looks great!
                    • Mistro11M Offline
                      Mistro11
                      Thanks for your replies! The only drawback with this method is that you lose detail from the bmp image as you smooth the geometry. With bigger waves the mesh tends to create jagged peeks so smoothing is necessary unless a higher resolution bmp is used which greatly increases triangle count. I'm still liking the results I'm getting so far.
                      @notareal: Yeah, read about that. Saw some work arounds but never tried yet. I did some tests in Kerkythea by using photon map caustics and I see a difference. The water looks more realistic and I do see some subtle shadow effects on the river bed during the irradiance calculation. This is probably because the surface is a mesh displaced and not simply a flat surface with a bump map applied. But with calm water in a swimming pool I get what you're saying.
                      @Gaieus: That looks really cool.
                      I found some water textures from http://texturelib.com/#!/category/?path=/Textures/water/water
                      Here are 2 more renders using a texture from above site.
                      This is a semi-calm one with a bitmap at 100x75 pixels
                      This one is more turbulent with photon map caustics and I raised bitmap resolution up to 150x113 pixels.
                      I forgot to mention that during the Bitmap2mesh operation, the height of the waves also depend on the height set on the blue axis. A shallower height would make calmer water. The calmer image in this post was set lower than the second more turbulent one. I forgot the heights but will get into the habit of making notes.
                      Using images from real waves looks a lot more convincing. I tweaked them in PS before applying. To solve the small detail problem (the smaller ripples on the bigger waves) I am trying to apply a bump map texture to the glass in Kerkythea but for some reason the bump from the image is not showing up. I applied a bump map to a flat plane and it showed just fine. It's a head scratcher. To be continued....
                      • pbacotP Offline
                        What is your smoothing method? Do you mean with Artisan?
                        • Mistro11M Offline
                          Mistro11
                          Yes, I use Artisan to smooth the geometry. Just one pass is good enough. It's not necessary on calm water. I did not smooth the water meshes in first 2 renders in this thread. I only had to do it with the last one in my previous post where some of the peaks had more height. So it's not something that must be done every time.
                            Do you have a wireframe view of that model? Would be interesting to see.
                            • Mistro11M Offline
                              Mistro11
                              Here ya go...
                              After making the water mesh, I then made it into a component and copied 2 times. I flipped the second mesh so the waves line up to avoid seeing a seam in the render. Was a bit scared to make a mesh on a very large scale at one time.
                              It looks worse than it actually is. The meshes took seconds to create on my 4 year old Q6600 Quad core.
                              • daleD Offline
                                dale
                                I'm following this with interest. A really nice method and results. Thanks for sharing.
                                • Bob JamesB Offline
                                  Bob James
                                  Following with interest πŸ‘ .
                                  Is the difference between wireframe 2 and wireframe 3 an intersection opertion? Then smoothing of the results?
                                  @Gaius
                                  Whose guitar music is that??? Super music.
                                    @bob james said:
                                    @Gaius
                                    I have no clue, Bob. I just grabbed an example from YT.
