    Offset and split?
    17 Posts 9 Posters 727 Views 9 Watching
      cuttingedge
      Following TIG's Christmas gift which is the smart offset which is great, Have I been missing something or is it one duh moment for me?
      Is there such plugin to offset a surface and will automatically divide it into quads. I know there is a split donut or split sausage to do that after offset operation. but I wonder if there is one that does that in one shot (which is quite common in other 3d apps)
      cuttingedge
      • Chris FullmerC Offline
        SU doesn't natively work in quads. But do you have a screen shot of what that function should look like?
        All my Plugins I've written
        • cottyC Offline
          cotty
          I need this very often and for me splitdonut and splitsausage works well because I can decide wheter I need the subdivision or not.
          Alternatively you can move the inner face a little bit up with forcing autofold and move it back afterwards, but this is also an extra step.
          my SketchUp gallery
            cuttingedge
            Thanks for your quick reply Chris. Here's what I mean. It is called inset in 3dsmax I believe.
            offset-with-split or inset
              rv1974
              Fredo's joint-push-pull already does it (temporally make a prism and offset it's all sides except
              the cap)
                cuttingedge
                Yes that's how we do it normally but as you said we use this very
                too often that one click could save us time, much so in finding the tiny floating toolbars like split tools. ๐Ÿ˜‰ It is very common in other 3d aps so I thought it should not be too complicated(but i may be wrong)
                It would be good if it function like the native (only with the splits)where you can drag or input value and wont execute till you hit enter.
                • cottyC Offline
                  cotty
                  Maybe TIG can combine his splittools with his new smart offset tool...
                  my SketchUp gallery
                  • panixiaP Offline
                    panixia
                    use extrude edges by offset from tig extrusion tools.. choose the option wich keeps the inner segments et voila.. i use it a lot to do exactly what you say here..
                      cuttingedge
                      I dont know exactly how you do it? Tried extrude edges by offset but doesnt work with closed edges. Gives me unpredictable and messy result with fairly simple geometry.
                      • panixiaP Offline
                        panixia
                        you are right! never noticed that.. maybe because i usually do this with open polylines..
                        • cottyC Offline
                          cotty
                          +1
                          There are no options for EEbO?
                          Edit: Ok, they are there for not closed edges!...
                          my SketchUp gallery
                          • soloS Offline
                            solo
                            This would make a very useful tool is available, if bundled with TIG's robust offset tool it would be brilliant
                            http://www.solos-art.com
                              Yes and with the Curviloft you can make several spaces ๐Ÿ˜‰
                              • srxS Offline
                                srx
                                Curviloft should be integrated in SketchUp 9.
                                www.saurus.rs
                                • Jean LemireJ Offline
                                  Jean Lemire
                                  Hi cuttingedge, hi folks.
                                  See this SU file for ideas if you want to practice with SU's native tools.
                                  Offset and split.skp
                                    cuttingedge
                                    Thanks Johnny, Yes its one way to do it. But I think, by far the most practical way ( if no single tool available) is native offset and TIG's split donut. Anyways, I just learnt that split donut work on multiple selections. So I would offset everything and split the surfaces in one shot.
                                    • cottyC Offline
                                      cotty
                                      That was new to me too, nice! ๐Ÿ˜„
                                      my SketchUp gallery
