    Problem with transparency rendering
    renderpluginsextensions
    5 Posts 2 Posters 716 Views 2 Watching
    • C
      conrad5
      I have a problem with transparency rendering. At first i thought its a problem with my self-made material, but I downloaded perforated steel material from the internet and the problem appeared again.
      My sketchup doesn't render full transparency and leaves glass like material in places where nothing should be. I have attached my rendered material and original material image.
      I hope anyone of you can help me. Thank in advance for your help.
      • andybotA
        andybot
        You need to include the alpha map in your perpendicular reflections slot to cut out the reflections in the transparent areas.
        • C
          conrad5
          Thank u for the reply. I did what u had written but nothing happened. The problem appeared again. Any other ideas?
          • andybotA
            andybot
            I put together a vismat of the material. There was no alpha map with the original material from flying architecture so I made a new one. It's not particularly high res, so it doesn't work so well for closeup.
            Hope this helps.
            Andy
            Metal_microperf.zip
            • C
              conrad5
              Now it works! Thank you for your help!
