    Crossing drilling holes
    12 Posts 5 Posters 709 Views 5 Watching
      Backstyler
      Hi folks,
      I'm a Sketchup newbie and have a question about crossing drilling holes.
      See screenshots attached.
      The holes are at the same height of the beam and should run entirely through it.
      However, at the crossing point both still have this mantle, which is visible when looking through the other hole.
      How can I fix this?
      Thank you!
        This is a case where you would select the geometry of both holes and use Intersect Faces>With Selection to create the required intersected surfaces. then select and delete the unwanted faces.
        Your holes start out as on the left. Notice there are no edges where the two cylinders cross. After the Intersect Faces step there are edges at the intersections. Then after deleting the unwanted faces, you have the desired result.
          You must be doing something incorrectly. I just made that example a few moments ago and it works exactly as I described. Perhaps you haven't got a complete intersection. Can you post the SKP file so I can see it?
            Backstyler
            When I do this, welds do appear in the form of lines at the intersection points of both holes. But when I try to select the unwanted area through one of the holes now, it selects both pipe surfaces together including the unwanted area in the middle.
              Backstyler
              Correction: I could only delete one of the four unwanted areas.
              See file attached (removed anything unnecessary).
              crossing holes.skp
                I see the problem. The initial circle you drew for the cylinder parallel to the green axis was drawn off axis. So the cylinders don't really intersect perfectly. Make life simple for yourself and always drag out the radius of circles on an axis. That will get vertices to align with other vertices. I would redraw that hole and try the intersect again.
                I've corrected the hole and then ran through the steps I described and it works just fine.
                crossing holes.skp
                  Backstyler
                  I see. Thank you very much for your support!
                    I'm glad that helped. I like those simple fixes.
                    In case anyone else comes along and wants more clarification, I made up an example that is easier to see.
                    On the left I've drawn two crossing holes using 12-sided circles. The yellow one is drawn off axis and you can see the two don't cross to form a point. On the right both circles are on axis. They do cross forming a point at the top.
                    • Jean LemireJ Offline
                      Jean Lemire
                      Hi Backstyler, hi folks.
                      Sometimes there is a need to use the Intersectfunction 2 or more times in a row to get a complete intersection.
                      Another possibility is that the model is so small that the edges that result from the intersection are below the lower threshold of SketchUp for automatic face generation. This phenomenon is often seen when using the Follow metool. This threshold is about 1/16 inch or about 1 millimeter.
                      The workaround is to model larger than lifesize and then to scale down when done. Suprisingly, faces that cannot be formed at very small size can exist when scaled down. The problem is only when creating them.
                      Just ideas.
                      • G Offline
                        g_wilson
                        Using OSCoolean and Hole On Solid plugins can make this much easier. I struggled making a "fittting" block for mounting to an air cylinder with an O-ring port - things like check valve - relief valve - quick disconnect. Required drilling intersecting holes that were 5/16 dia bores but counterdrilled & tapped for 1/4 NPT fittings. Making a "plug" solid group and then using OSCoolean ,especially, made it easy. Can use same plug for different depths using move and/or scale to adjust diameters and depths. Holes included 118 degree drill point (common drill point included angle).
                        Cross Drilling.skp
                        • pbacotP Offline
                          That's a good plugin maybe, but the OP's problem couldn't be much easier than by Dave's method. Easier than downloading a plugin.
                            And the key problem he had was caused by having drawn one circle off axis which a plugin won't fix.
