    Req: Distribute Spacing plugin.
    29 Posts 13 Posters 3.8k Views 13 Watching
    • X
      xyzt
      I would like to request a plugin that does Distributed Spacing like in Adobe Illustrator, Photoshop, etc. (see image)
      Would this be possible, and if so I anybody up for the task?
      Kind Regards,
      xyzt
      • TIGT
        There are already some 'Align' tools that might do what you want 'out-of-the-box' - search the SCF 'Plugins Index', or look through Didier's 'Ruby Depot' at crai...
        • X
          xyzt
          I have checked your suggestions, but they don't do what i'm looking for. I came across some very useful plugs do, thanks!
            See Align, Distribute tools by Sdmitch πŸ˜‰
            • sdmitchS
              sdmitch
              I don't remember hiring Pilou as my publicist but, since he has choosen to advertise my Align and Distribute plugin, there are a few things that need be explained.
              The plugin uses the corners of the bounding box to compute the spatial relationship of the selected objects. The orientation of the object determines where these corners are located. For instance, if the object is on the XY plane, corner(0) is the front lower left and corner(4) is the front upper left. If the object is then rotated 90 degrees around the X axis,what was corner(0) is now corner(2) and what was corner(4) is now corner(0). Simuliar changes occur if the objects are rotated around the Y or Z axis. That is why the alignment option you pick MUST match the situation of the objects.
              http://sdmitch.blogspot.com/
              • X
                xyzt
                [attachment=0:2xoeljzs]<!-- ia0 -->distribute.jpg<!-- ia0 -->[/attachment:2xoeljzs]
                Hehe, thanks for suggesting, the funny thing is that sdmitch and I have been PMing back and forth about this plugin. He did a really really great job programming it!. I didn't realized that he already made it available. There where some problems on my mac, but het has just fixed it. I'm really extremely happy with this plugin. It a dream come true. For what I do with sketchup this is a real big time saver. So one big round of applause for sdmitch!
                😍 😍 πŸŽ‰ πŸŽ‰ 😍 😍 πŸŽ‰ πŸŽ‰ 😍 😍 πŸŽ‰ πŸŽ‰ 😍 😍
                • jolranJ
                  jolran
                  So while you thought Sdmitch was spending labour time working on his plugin you make a request here to see if someone could beat him to it? πŸ˜‰
                  • N
                    nickchun
                    Just tried this plugin. Very useful thanks. Question though, if you want the spacing to be zero so that objects are touching it doesn't respond. I have to give a spacing of 0.1, but then get cumulative 'inaccuracies' with overall dimensions. Is this a limitation of SU?
                    • sdmitchS
                      sdmitch
                      Currently a spacing of zero triggers the distribution of the objects between the first and last. I could make the trigger a negative distance so zero would be valid.
                      • JClementsJ
                        JClements
                        Sdmitch:
                        I am not sure the how the DOWNLOAD works on your site for the Align&Distribute script and how the script's files should be organized in the user's SU/Plugins directory structure.
                        Please advise.
                        Thanks, John
                        • N
                          nickchun
                          Sam, that would be ideal or if you want to let me know what to change in the script so I can modify my copy. It is a good way to check that my components are not overlapping.
                          Thanks...
                          • sdmitchS
                            sdmitch
                            @jclements said:
                            Sdmitch:
                            Please advise.
                            Thanks, John
                            In the case of Align & Distribute, the plugin and supporting files are contained in a zip file. Extract them to the Sketchup Plugins folder or where ever you prefer.
                            • sdmitchS
                              sdmitch
                              Thanks...
                              Only one change is required. Change line 172 from
                              space=self.calc_space(@ents) if space==0
                              to
                              space=self.calc_space(@ents) if space<0
                              • N
                                nickchun
                                Thank you very much. Will give it a go...
                                • Z
                                  zstadel
                                  [attachment=1:5touco9j]<!-- ia1 -->distribute.jpg<!-- ia1 -->[/attachment:5touco9j]
                                  I'm also on a Mac and having problems. The dialog box for alignment isn't loading when I click on Plugins>SDM Tools>CorG Tool>Align and Distribute. If this was the same problem you were having, can you please post the fixes you were PMing about?
                                  Thank you
                                  Z
                                  • J
                                    jeronimoven
                                    hello,
                                    same problem,
                                    i unzipped the plugin in the plugin folder,
                                    i restarted SU,
                                    but when i click on align and distribute in the plugin menu, i get NO-Thing...
                                    sdmitch, can you help us ?
                                    best regards
                                      @sdmitch said:
                                      @jclements said:
                                      Sdmitch:
                                      Please advise.
                                      Thanks, John
                                      Sam, I am guessing that John is seeing the same thing I do when I go to your page listing the plugins you've written and click on "Plugin" for this one. It looks like this:
                                      It looks like the contents of the ZIP file but there's no sign of the ZIP file itself. I've seen this with some of your other plugins as well although I haven't looked through them all.
                                      Clicking on File>Download gets the ZIP file but it isn't all that obvious. I expect he was expecting to see a hyperlink like Align and Distribute.zip.
                                      • panixiaP
                                        panixia
                                        @jeronimoven said:
                                        hello,
                                        same problem,
                                        i restarted SU,
                                        best regards
                                        same problem here.. i hope there's a way to fix the problem because this plugin looks pretty much amazing.. πŸ‘
                                          @panixia said:
                                          @jeronimoven said:
                                          hello,
                                          same problem,
                                          i restarted SU,
                                          best regards
                                          Are you preselecting the objects you want to align?
                                          • BoxB
                                            Make sure the folder 'AnD_Support_Files' that is in the zip file is extracted to the plugin folder also. And check that you have the folder security permission set correctly.
                                            • 1 / 2
