    Slicing / cutting away
    4 Posts 3 Posters 256 Views 3 Watching
    • O Offline
      oldnewt
      SU8/windows xp
      Good morning all - can anyone help with slicing? In particular, I am working with sip panels, and am trying to cut away through both sides of a house. I am not having success with zorro2 - are there any other options? I also tried section plane tool - but need the slice to be on an angle - it seems section only works vert or horiz.
      Thanks!
      • Rich O BrienR Online
        You can rotate Section Planes like any other object using the rotate tool.
          Or you can set up some temporary geometry (a face like a rectangle) in any position and then apply the section plane snapping to that.
          • O Offline
            oldnewt
            Thank you both!
