    2D Fillet
    6 Posts 3 Posters 562 Views 3 Watching
    • B
      Ben Ritter
      Not sure which forum this should be posted in, but I get a bugsplat when using the 2d fillet tool on more than one corner of a surface.
      Below is my list of plugins. Could any of these be causing the problem?
      Thanks for the help.
      • massimoM
        massimo Moderator
        I don't know about the bugsplat, but may I suggest Fredo's Bezier Spline plugin? It has a fillet feature (select the edges-->right click-->BZ-convert to-->Polyline arc corners) and many more. πŸ˜„
        • TIGT
          Do you have the latest version [5.3] http://sketchucation.com/forums/viewtopic.php?p=185760#p185760
          A rare Bugsplat was reported with the Fillet tool and it was fixed [avoided] with this update.
          Another script was adding a persistent 'EntitiesObserver' and this was sufficient to break the innocent fillet tool.
          The culprit that time was 'BuildingEdgePlan'.
          Some versions of Podium, SketchyPhysics etc can also cause problems with several other scripts because they mess with the base classes of 'groups'...
          If you read the last few recent posts in the 2dTools thread it's covered in some detail there...
          Why didn't you post in that thread in the first instance ?
          • massimoM
            massimo Moderator
            Well I don't have the "2d tools" plugin by TIG, but I'm sure it also can do that and more. πŸ˜‰
            • B
              Ben Ritter
              That did it. Thank you for the suggestion.
              I don't know, I guess I never bothered to look for that particular thread.
              Thanks again for pointing me in the right direction.
              • B
                Ben Ritter
                Massimo,
                Thank you for the suggestion. I will have to try them as well.
                Ben
