    Reflection effects on perforated material
    renderpluginsextensions
    7 Posts 5 Posters 1.4k Views 5 Watching
    • H Offline
      howardhong
      is there anyone who succeed to give reflection on perforated material using VfSU 1.49.01?
      (Stucked IOR 1.55 and metrial editor shows reversed results using with/without .PNG)
      • andybotA Offline
        andybot
        can you post an image and share your material settings (you can save as a vismat) hard to know what's wrong without some more info.
        • H Offline
          howardhong
          heres test renderings
          renered IOR 1.55
          can see light leaks through holes in perforated sheet
          http://i241.photobucket.com/albums/ff294/howardhong/IOR155.jpg
          rendered IOR 10.0
          see defferences
          http://i241.photobucket.com/albums/ff294/howardhong/IOR100.jpg
          rendered by 1.05.30
          http://i241.photobucket.com/albums/ff294/howardhong/perforated_sst_applicable2.png
          Perforated sheets.zip
          2_squar_lights.zip
          • broomstickB Offline
            broomstick
            hi there! You don't see reflections, because the lamp cage is a single surface. Try to give it some thickness and be sure to put positive normal faces facing the bulb πŸ˜‰
              Reflection doesn't need thickness - it can well be on a single thing surface.
              It's refraction that needs thickness.
              • H Offline
                howardhong
                i guess its one of BUGs that wont happen in 1.05.30
                we,sorry, i cant give any reflection or refraction effects on perforated materials
                i cant give any effects on leaves of trees for expecting reflecting lights on
                we have so many versions of VfSU, nothing useful except 1.05.30
                Tired to transfer materials to new version to adjust all factors just like this
                since after closing the site of ASGVIS, many changes happen to VfSU, but useless.
                  rspierenburg
                  Quick question to the OP. Did you use the same vismat for both instances? The reason I ask is because I know that there have been some issues using older vismats with the newer version of the VRaySU. You could try re-building your material from scratch in the newer version to see if that works better.
                  Rob
