    Helix follow me - valid path
    11 Posts 6 Posters 2.1k Views 6 Watching
    • cottyC
      cotty
      Any idea why this is not a valid path for the follow me tool?
      helix_followme.skp
      my SketchUp gallery
      • kenK
        ken
        Don't know if this helps. I have found that sometimes lines that have this error, the error will disappear if you click on the other end. Not sure why the order of end selection is important.
        Note, my lines used have not been that complicated.
        Ken
        • cottyC
          cotty
          Ken
          Thank you for the suggestion, but it didn't help in this case.
          @ely862me said:
          You can use some plugins though, tube along a path is one of them or lines to tubes and there are a few others.
          How did you draw this type of helix anyway ?
          I didn't thought that this would be a problem with the follow me tool...
          (I will make a little tutorial file with the manual helix creation)
          With a shorter helix it works!?...
          my SketchUp gallery
          • ely862meE
            ely862me
            Same happens to me too (I assume that the path is too complicated for the tool-also the new geometry will make sketchup kneel).
            I welded the segments and I used Follow me manually and it worked(unfortunately I am rendering something and the operation didn't finished because sketchup stopped responding).
            Elisei (sketchupper)
            Come and See EliseiDesign
            • cottyC
              cotty
              Here is a short making of...
              my SketchUp gallery
              • ely862meE
                ely862me
                I knew how to draw the helix itself but I haven't thought about using component stringer for making the other helix . Great tip ! Thanks !
                I will try it as soon as I have some time !
                EDIT
                Ok, I got time πŸ˜„ . This is a great tutorial, I think it should be placed somewhere in the tutorials area. Btw, there is a small plugin(I don't know its name right now) that will draw helix so you won't waste that much time.
                • pbacotP
                  screw.rb is pretty nice for the basic helix
                  • massimoM
                    massimo Moderator
                    Do you know Kito Raupp? Check on youtube, there are many great videos. πŸ˜‰
                    • GaieusG
                      πŸ‘
                      I especially like them because he uses basic, native tools to achieve everything. I mean plugins are great but without learning the basis, one will never be as efficient as possible and once a problem arises, may be just stumped.
                      @Cotty: this helix[sup:33e1xsld]helix[/sup:33e1xsld] (to finally test our superscript bbCode πŸ˜„ ) is something stunning! πŸ‘ πŸ‘ πŸ‘
                      • massimoM
                        massimo Moderator
                        πŸ‘ πŸ‘
                        • cottyC
                          cotty
                          Yes, I think there are several plugins that would be helpful here, but...
                          @Cotty: this helix[sup:1mzq0s1l]helix[/sup:1mzq0s1l] (to finally test our superscript bbCode πŸ˜„ ) is something stunning! πŸ‘ πŸ‘ πŸ‘
                          Thank you!
                          Yes! I've bookmarked him already πŸ˜‰
                          my SketchUp gallery
