    Air flow plugin or simulation
    4 Posts 3 Posters 3.6k Views 3 Watching
    • H Offline
      hulahopka
      Hi. i wonder if exist any plugin for simulate air flow in sketchup or software where I can use SU files for air or water flow ? I know I solidworks etc, but there you must be almost NASA ing. to produce something usable.
      So my question is is any solution for this case ?
      Thank you.
        If I recall there was one that did something like this - VirtualWind - but I think that it's no longer supported by its inventor, and worse still it messed with several vital base-class functions and some third-party tools methods that it was shunned and effectively 'quarantined'... See
        http://sketchucation.com/forums/viewtopic.php?p=353144#p353144
        and my [partial] fixes version [zipped]
        http://sketchucation.com/forums/viewtopic.php?p=331981#p331981
        If you must read up on it and use with extreme caution!
          sketchymick
          It sounds like you're talking about cfd modelling? There is one plugin I've come across called Khamsin which uses openfoam.
          Cheers
          • Mick
          "I love the sound that deadlines make as they rush past"
          • H Offline
            hulahopka
            Hi. I find that Khamsin plugin, it look little complicated πŸ˜„ But I wiil try anyway maybe is only look that, I design some kind of air nozzle for my hobby project.
            Thank you very much.
