    Zorro+SU8+vray = section????
    renderpluginsextensions
    5 Posts 3 Posters 908 Views 3 Watching
    • J
      jennk42
      I have a model that I sliced using zorro and am trying to render. The problem is the render size, vray does it too far away or too close up. I have tried deselecting physical camera but then nothing renders but a bright white screen. How can you control the output? I am using parallel view looking right at the section I created. Thanks!!
      • chonC
        chon
        Hello,
        VRay can't render paralell and native SU section views.
        For the section view, maybe VRay can render zorro section views, i don't know. If not, the only way is to really cut your SU project.
        For the paralell view, turn to perspective mode and set the zoom tool to 1Β°. You'll have something near paralell mode. πŸ˜‰
        SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
        • J
          jennk42
          Thanks! That worked!
          you can render sections once you slice it using 2 plug ins. In case anyone is interested here is a link to one method:
          http://ankitsurti.blogspot.com/2011/11/how-to-render-section-cut-from-sketchup.html
          • chonC
            chon
            πŸ‘
            • V
              valerostudio
              Thanks for the link. Wish I had that 3 months ago when I worked on past project. I should mention that I did not have much luck with Zorro with a very complex high poly model imported from Revit.
