    Rendering Terms on the SketchUp Sage Site
    13 Posts 5 Posters 14.1k Views 5 Watching
    • Al HartA
      Al Hart
      I have been working on the Rendering Terms section of the SketchUp Sage site. (Brought over from the former SuWiki)
      These are for all forms of rendering - SU OpenGL, Photorealistic, Non-Photorealistic.
      What ideas do you have that would be good additions to the list. And if you take a look at them and want to suggest improvements let me know (Or volunteer to help edit the SketchUp Sage site)
      Al
      Here are the terms we have now (not all the write-ups are complete)
      A
      Alpha Channel
      Ambient Light
      Anti-Aliasing
      B
      Batch Rendering
      Bump Mapping
      C
      Caustics
      Clay Rendering
      Cove Lighting
      D
      Depth of Field
      E
      Edge Highlighting
      F
      Fog
      Fractal Plants
      G
      Global Illumination
      Glow
      H
      HDRi
      I
      Indirect Lighting
      L
      Lighting Channels
      M
      Mirror
      Morphing
      Motion Blur
      N
      Non-Photorealistic Rendering
      Normal
      O
      OpenGL
      P
      Panorama
      Perspective
      Photorealistic
      R
      Radiosity
      Ray Trace
      Reflection
      Refraction
      Renderer
      Rendering
      RPC Objects
      S
      Section Plane
      Shading
      Shadows
      Silhouette
      Soft Shadow
      Solid Materials
      Specular Reflection
      T
      Texture Mapping
      Translucency
      Transparency
      X
      X-Ray
      Z
      Z-Fighting
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • D
        driven
        frustum
        john
        • GaieusG
          Some more (in alphabetical order):
          Alpha mask render
          Animation (camera and object)
          Atmosphere
          Biased rendering
          CPU rendering
          Depth map render
          Displacement (map)
          Double sided materials
          Ecosystem
          Gamma value/correction
          GPU rendering
          Layered materials
          Lighting analysis/study
          Instancing
          Interactive rendering
          Photon mapping
          Procedural material
          Proxy
          Real time rendering
          Shift lens
          Texture baking
          Unbiased rendering
          Walkthrough (export)
          • Al HartA
            Al Hart
            Thanks for these ideas. They are well thought out.
            Al Hart
            • GaieusG
              Speaking of specifically renderers for SketchUp, maybe rendering PhotoMatched models would also be interesting (with its specially distorted materials).
              • Al HartA
                Al Hart
                Alpha Mask Rendering
                I am familiar with creating a rendering which fills the alpha channel of the .PNG image wherever there is background.
                http://wiki.renderplus.com/images/5/54/Engine-alpha.png
                This makes it easy to place the rendering in front of a background in PhotoShop.
                However, some other renderers have a different definition
                From Kerkythea:
                [pre:2ik0fsac]Mask Render (Alpha Mask)
                Renders a black and white image for a selected object in the scene representing
                the spatial relationship of the selected object to its field. This is commonly
                used in conjunction with a photo editing program in order to ‘mask’ an object
                using the mask render in the ‘Alpha’ channel.[/pre:2ik0fsac]
                And from Pheoonix Viewer:P
                [pre:2ik0fsac]Alpha Mask Rendering: These option control when alpha masking should be
                used in an attempt to mitigate the well known alpha sorting issue, in which
                prims behind other prims may appear to flicker in front. Please note that enabling
                this can have side effects of its own, since as objects not rendering at all.[/pre:2ik0fsac]
                These both imply that the alpha channel is applied to individual objects rather than the whole scene.
                Can you add any insight?
                Al Hart
                • FrederikF
                  Frederik
                  Why are the reflections so pixel-ated (if that's the right term)...?
                  Cheers
                  Kim Frederik
                  • Al HartA
                    Al Hart
                    This was rendered with a very low resolution HDRi sky. The idea here was to have imprecise reflections, which do not represent any actual object. The HDRi is actually a forest, with light filtering through - but we didn't want to see the actual trees and leaves - but rather a generic impression of shadows and highlights. (I think it works well when placed in the warehouse setting. Because the highlights are imprecise, the eye might imagine they come from the lights in the warehouse)
                    If you render with a higher resolution HDRi sky, you get more precise reflections.
                    The purpose of the example here, however, was to show the effect of the Alpha Mask in the image.
                    Al Hart
                    • mitcorbM
                      mitcorb
                      I didn't notice the term "instancing" or variations of this in the lists. Would this be appropriate to add?
                      Edit: Scratch this comment, as Gaieus did have it in his list.
                      • GaieusG
                        Yes, I collected some terms that I encounter daily here from my "recollection" (not as if I ere a great rendering talent* - or even biased towards any particular rendering engine). Hanging out on the forums, they just stick on me...
                        *Some folks would even call me "a rendering idiot" 😄
                        • Al HartA
                          Al Hart
                          And you even alphabetized everything - except things that start with I - like Instancing.
                          Thanks for inspiring me - I have added 3 of these to the Sage site already.
                          Double Sided materials
                          Displacement Mapping
                          Feel free to add criticisms, or other ideas.
                          Al Hart
                          • GaieusG
                            Hehe. You got me. I should go back to school. 😄
                            Does iRender do displacement mapping? I did not know that, great!
                            • Al HartA
                              Al Hart
                              Does IRender do displacement mapping? I did not know that, great!
                              Yes - but we haven't found a great use for it yet. We worked on a ruby to create bump maps and displacement maps from SketchUp models. Basically you render the scene - say a wall with 3D depth - or a window treatment - of rocks - with a camera point straight on - in OpenGL - but save a greyscale image using the Z-depth for the intensity, and then use it as a bump map or displacement map. (This could be done purely in Ruby as well by getting the Z-distance at each pixel and creating an image using the Z-distances for greyscale intensity)
                              It was hard to find a good example for it. e.g. Background windows which would have many fewer faces in SketchUp - but still render will from different angles because of the mapping.
                              Here is a sample from of the image from the procedure - which we wrote for experimentation but never put into a product.
                              http://wiki.renderplus.com/images/d/d3/Rock-bump-images.jpg
                              The problem was creating a SketchUp model good enough to use for the bump maps. A brick wall would be easy - but it also easy to create a decent bump map for brick using Paint.
                              So you need a more complex sculptured surface - or rocks. When we asked at the time no one could supply a good model of rocks which would be useful for creating a bump map or displacement map image.
                              Al Hart
