    Rendering Terms on the SketchUp Sage Site
    13 Posts 5 Posters 14.1k Views 5 Watching
      driven
      frustum
      • GaieusG
        Some more (in alphabetical order):
        Alpha mask render
        Animation (camera and object)
        Atmosphere
        Biased rendering
        CPU rendering
        Depth map render
        Displacement (map)
        Double sided materials
        Ecosystem
        Gamma value/correction
        GPU rendering
        Layered materials
        Lighting analysis/study
        Instancing
        Interactive rendering
        Photon mapping
        Procedural material
        Proxy
        Real time rendering
        Shift lens
        Texture baking
        Unbiased rendering
        Walkthrough (export)
        • Al HartA
          Al Hart
          Thanks for these ideas. They are well thought out.
          Al Hart
          IRender nXt from Render Plus
          • GaieusG
            Speaking of specifically renderers for SketchUp, maybe rendering PhotoMatched models would also be interesting (with its specially distorted materials).
            • Al HartA
              Al Hart
              Alpha Mask Rendering
              I am familiar with creating a rendering which fills the alpha channel of the .PNG image wherever there is background.
              http://wiki.renderplus.com/images/5/54/Engine-alpha.png
              This makes it easy to place the rendering in front of a background in PhotoShop.
              However, some other renderers have a different definition
              From Kerkythea:
              [pre:2ik0fsac]Mask Render (Alpha Mask)
              Renders a black and white image for a selected object in the scene representing
              the spatial relationship of the selected object to its field. This is commonly
              used in conjunction with a photo editing program in order to ‘mask’ an object
              using the mask render in the ‘Alpha’ channel.[/pre:2ik0fsac]
              And from Pheoonix Viewer:P
              [pre:2ik0fsac]Alpha Mask Rendering: These option control when alpha masking should be
              used in an attempt to mitigate the well known alpha sorting issue, in which
              prims behind other prims may appear to flicker in front. Please note that enabling
              this can have side effects of its own, since as objects not rendering at all.[/pre:2ik0fsac]
              These both imply that the alpha channel is applied to individual objects rather than the whole scene.
              Can you add any insight?
              Al Hart
              • FrederikF
                Frederik
                Why are the reflections so pixel-ated (if that's the right term)...?
                Cheers
                Kim Frederik
                • Al HartA
                  Al Hart
                  This was rendered with a very low resolution HDRi sky. The idea here was to have imprecise reflections, which do not represent any actual object. The HDRi is actually a forest, with light filtering through - but we didn't want to see the actual trees and leaves - but rather a generic impression of shadows and highlights. (I think it works well when placed in the warehouse setting. Because the highlights are imprecise, the eye might imagine they come from the lights in the warehouse)
                  If you render with a higher resolution HDRi sky, you get more precise reflections.
                  The purpose of the example here, however, was to show the effect of the Alpha Mask in the image.
                  Al Hart
                  • mitcorbM
                    mitcorb
                    I didn't notice the term "instancing" or variations of this in the lists. Would this be appropriate to add?
                    Edit: Scratch this comment, as Gaieus did have it in his list.
                    • GaieusG
                      Yes, I collected some terms that I encounter daily here from my "recollection" (not as if I ere a great rendering talent* - or even biased towards any particular rendering engine). Hanging out on the forums, they just stick on me...
                      *Some folks would even call me "a rendering idiot" 😄
                      • Al HartA
                        Al Hart
                        And you even alphabetized everything - except things that start with I - like Instancing.
                        Thanks for inspiring me - I have added 3 of these to the Sage site already.
                        Double Sided materials
                        Displacement Mapping
                        Feel free to add criticisms, or other ideas.
                        Al Hart
                        • GaieusG
                          Hehe. You got me. I should go back to school. 😄
                          Does iRender do displacement mapping? I did not know that, great!
                          • Al HartA
                            Al Hart
                            Does IRender do displacement mapping? I did not know that, great!
                            Yes - but we haven't found a great use for it yet. We worked on a ruby to create bump maps and displacement maps from SketchUp models. Basically you render the scene - say a wall with 3D depth - or a window treatment - of rocks - with a camera point straight on - in OpenGL - but save a greyscale image using the Z-depth for the intensity, and then use it as a bump map or displacement map. (This could be done purely in Ruby as well by getting the Z-distance at each pixel and creating an image using the Z-distances for greyscale intensity)
                            It was hard to find a good example for it. e.g. Background windows which would have many fewer faces in SketchUp - but still render will from different angles because of the mapping.
                            Here is a sample from of the image from the procedure - which we wrote for experimentation but never put into a product.
                            http://wiki.renderplus.com/images/d/d3/Rock-bump-images.jpg
                            The problem was creating a SketchUp model good enough to use for the bump maps. A brick wall would be easy - but it also easy to create a decent bump map for brick using Paint.
                            So you need a more complex sculptured surface - or rocks. When we asked at the time no one could supply a good model of rocks which would be useful for creating a bump map or displacement map image.
                            Al Hart
