    SU is loaded but I can't see anything!
    17 Posts 5 Posters 968 Views 5 Watching
    • G
      gkontomi1990
      Hello guys! I have just fomated my pc and loaded windows 7 64bit
      I previously had windows 7 32 bit and SU pro 8 was working like a charm
      I installed SU pro 8 on the newly formated pc and even it seems that there is no problem during the installation and at the loading, i can only see the toolbars. The only thing i see is the background of my pc!
      I unistalled it, tried both the free and pro version but same result!
      any help would be much appreciated!
      SU pro 8
      • utilerU
        utiler
        I can see autumn leaves and green grass... ๐Ÿ˜’
        Seriously, try minimising SU then maximise again; happens from me time to time.
        Just Curious...
        • mitcorbM
          mitcorb
          Does Sketchup automatically install itself in C>ProgramFiles(x86), as opposed to just ProgramFiles, or do you have to tell it where? I can't remember ๐Ÿ˜ณ This may not have anything to do with your issue.
            Well that's a new one on me.
            Have you tried manipulating the OpenGL settings in Window>Preferences? What is the graphics card/chipset?
            • G
              gkontomi1990
              First of all the autumn leaves and green grass is my desktop background ๐Ÿ˜„
              mitcorb you are supposed to tell it where to install, but as we all know SU installs even in 64 bit as a 86 program!
              Dave R what do you mean by saying to manipulate the OpenGL settings???
              I have an Nvidia GeForce 130 GT 1GB, there is no way I have that kind of a problem!
                No way, huh? So it sounds as if you're unwilling to even try changing the OpenGL settings. Whatever. ๐Ÿ˜’
                • thomthomT
                  It looks to be a graphic card issue. (Verify by temporarily disable Hardware Acceleration under Preferences -> OpenGL. If the viewport comes back then it's a graphic card issue.)
                  Could be the driver - have you updated the drivers?
                    That's what I was thinking but he's sure it isn't related to the OpenGL settings nor the graphics card.
                    • thomthomT
                      Well, I'm still betting on the graphic card and drivers. Until it's been eliminated from the list, as in actually testing by disabling hardware acceleration, I'd not debug any further.
                        I agree 100%.
                        • G
                          gkontomi1990
                          Guys the first thing that came to my mind was the graphic card!
                          But how can my computer run programs like 3ds max, pro evolution soccer 13 and nba 2k13 and not running sketch up???
                          Can you give me step by step guidance in order to testify if there is a card driver or anything else problem!
                          Thank you in advance!
                          • G
                            gkontomi1990
                            hey guys I've just disabled the hardware acceleration and the viewport came back! ๐Ÿ˜ฎ
                            So as you said it is a graphic card issue! The thing is that i' ve just updated the drivers from the device manager!
                            Any suggestions???
                            • G
                              gkontomi1990
                              here is a screenshot of the graphic card diagnostics!
                              • thomthomT
                                I'm guessing those uses DirectX - SketchUp uses OpenGL. Seems to be an OpenGL issue with your graphic card.
                                A bit strange - as nVidia cards works best with OpenGL than any other brands I've used. I'm not sure what the problem might be. Maybe a regression in the latest drivers?
                                What if you try different AA modes in the OpenGL preferences of SketchUp?
                                • G
                                  gkontomi1990
                                  What do you mean by that?
                                  • thomthomT
                                      Amazing.
