    3D-Printing
    5 Posts 5 Posters 2.9k Views 5 Watching
    • E
      enhydra
      I want to prepare the model below for 3D printing. The haus was build without interior design, just a shell. When I order a print from Shapeways I get a totally filled model and therefore it turns out very expensive. Is there a plugin available where I can set something like a wall thickness (let's say 1mm)? Something like this would help very much, because I'm to lazy to do all the modelling by hand. πŸ˜‰
      Kurt
      House.skp
      • ely862meE
        ely862me
        Joint Push&Pull !! http://sketchucation.com/forums/viewtopic.php?t=6708
        House a.skp
        Elisei (sketchupper)
        Come and See EliseiDesign
        • A
          andre51
          Hi enhydra
          They should be able to set the "skin" or outer shell to only print a certain thickness. We do it on our little printer and it is a very simple process. Maybe you should just ask them.
          Andre
          • D
            d12dozr
            @andre51 said:
            Hi enhydra
            Andre
            Unfortunately, it doesn't work that way with print services. What you upload is what you get. Print services typically operate on an automated system, and this kind of customization is too much for current systems.
            http://goo.gl/f7ooYh
            • M
              meister-mischler
              @ely862me:
              Joint Push&Pull !! viewtopic.php?t=6708
              That sounds good. I'll give it a try. Thanks
              @andre51
              Yes, that's right. I'll ask Shapeways, what they can do for me.
              So do we. πŸ˜„ We can define (to) many parameters. πŸ˜‰
              @d12dozr:
              Exactly! That's why I was looking for a plugin.
