    Sketchup 9 - a long wait.
    19 Posts 10 Posters 3.5k Views 10 Watching
    • P Offline
      Phillip
      Its been a long time since i posted on here, from memory contributing some dynamic components as a thank you for all the plugins that have been leached.
      Thought i would post as it seems an eternity since version 8 was released.
      With Google having dropped sketchup and engineering based Trimble taking it up, one cant help feel that the Sketchup progress under the Google business model may faulter or change direction. The silence from the Sketchup development team has been deafening of late, perhaps as they come to grips with the broad range of Trimble offerings that they may need to be integrating.
      As this place is not awash with engineers and the like I imagine many here are keen to see what Sketchup 9 brings, not only in terms of features and capability, but also as a flag for any direction change.
      Sketchup is a remarkable tool, its capability/price point and intuitive interface see it stand alone in a market flooded with 3d offerings. A development step sideways could see this change, the silence from the old Sketchup team does little to a lay the dissonance naturally felt - i don't see Sketchup 8 as a definitive solution nor do I relish the prospect of finding a replacement.
      I can only hope the old Sketchup team has remained intact up to this day and are being left to determine the direction of the product, though as time passes I am becoming more doubtful.
      Best regards to you all. πŸ˜„
      " - USE AT YOUR OWN RISK - "
        d12dozr
        Attendees of Basecamp this week tell us that there will be no "Sketchup 9". Instead, Sketchup will update yearly, with the next version being Sketchup 2013 next year.
        Sketchup did release some new stuff - a better console for Ruby developers, and an improved 3D printing plugin. You can see that stuff here: https://github.com/SketchUp
        http://goo.gl/f7ooYh
        • pbacotP Offline
          Marcus,
          Is this STL plugin usable for the casual (layman) user or is this something that only developers would be interested in at this stage. Asking as someone who know little about STL or 3d printing.
            Jim
            @pbacot said:
            Marcus,
            The extension is usable.
            SketchUp (with permission) has re-licensed and packaged together 2 long available community plugins into the extension. One plugin is my jf_stl_importer.rb importer and the other is the guitar-list dxf_to_skp.rb exporter.
            Right now, the main difference between the individual scripts and the scripts in the extension is that skp_to_dxf exporter now creates its menu under File > Export STL. STL Importer is still available from the File > Import menu. Otherwise, no new functionality has been introduced beyond what has already been available.
            If you install the SketchUp-stl extension, you can remove the other 2 scripts.
              d12dozr
              Yep, what Jim said. I'm a long time user of the STL Exporter, without any knowledge of Ruby. πŸ‘
              • andybotA Offline
                andybot
                Hmmm, what does that mean for pro licensing? An annual upgrade fee? Subscription? I keep thinking of getting pro sometime, but this would add to the calculus of whether it's worth it or not.
                Andy
                  It pretty much has. And now, under Trimble, we'll see more progress to the actual application. Google pretty much shackled SketchUp for it's own integration with Google Earth/Maps.
                  And the integration Trimble will do with SketchUp will be in the form of Extensions (plugins). So expect SketchUp's core nature to remain.
                  • jason_marantoJ Offline
                    jason_maranto
                    Ugh, this is what I was afraid of... 🀒
                      ? Afraid of what?
                      That SketchUp remains the same? And whatever Trimble wants to integrate comes as extension packages for those who needs it - leaving SketchUp untouched. ?? Did I not udnerstand you - or did you misunderstand me?
                        jason_maranto
                        I suppose maybe we misunderstood each other, but I think it may be a difference of opinions about how exactly to interpret that comment.
                        You see SketchUp staying the same as a desirable outcome -- I do not. Furthermore, since the bulk of Trimbles interests will be represented as separate "extensions" the bulk of the development time and energy will be expended on those extension instead of on making Sketchup itself better.
                        The SketchUp I see is already many years behind, looking like and working very much as a pre-2006 era tool... I blamed this on Google, and had hopes new ownership would rectify the problem.
                        Best,
                        Jason.
                          No - the SketchUp team will not be doing the integration work for the rest of the Trimble products. They will make it possible for them to integrate. And that means more attention to the Ruby API for instance - and everything that the other Trimble products uses to integrate with SketchUp will be available to everybody else.
                          I did not mean that SketchUp would not gain features etc. But most people has been afraid that Trimble would transform SketchUp into a different product - it will not.
                          Exactly, Google was only interested in SketchUp as an integration to Google Earth/Maps. They retrained further product development.
                          Having talked, a lot, with the SketchUp team at Basecamp I'm very excited about the future of SketchUp. They are preparing to get very busy - they already are. But as you can see on the Trimble website, they are hiring quite a few people.
                          • PixeroP Offline
                            Pixero
                            I'm more positive about SketchUps future than I have been these last years when Google owned it.
                            So, Thomthom, will you move over there?
                              Wouldn't that be nice πŸ˜„
                              • Bob JamesB Offline
                                Bob James
                                **After **you finish your latest new plugin πŸ˜†
                                IMO you should change your avatar to a picture of you wearing your "iconic" hat you had on at Basecamp πŸ˜„
                                  I would hope that existing issues with sketchup (Known by everyone here so no need to repeat them) would be addressed before adding more features but it seems not to be. More and more I come to the conclusion that the core free edition should have proper fuctnionality and the pro should have the additional features to bring greater difference from the free version. Not suggesting that the free version should be dumbed down but if folk want more and more features they should buy a level of the pro version, this is done in many cad programs already and works well.
                                    They did say at Basecamp that there will be bigger differences between free and pro in the future.
                                    • P Offline
                                      Phillip
                                      d12dozr
                                      Thanks for the info on the yearly updates for Sketchup starting 2013. πŸ˜„
                                      Andy
                                      Musing about what flavour future Sketchup licences will take is possibly putting yourself through the mill for nothing, the update to Sketchup 2013 could arrive as late as December next year. Enjoy the day. πŸ˜„
                                      Thomas
                                      Its heartening to hear that Sketchup team is still intact. Perhaps I differ in the value placed on Googles involvement with Sketchup, under their umbrella Sketchup became very much mainstream and for that i am grateful. It is easy to find people proficient in Sketchup.
                                      Jason
                                      I share some of your concern about the Trimble's likely desire to place a heavy emphasis on integration on their existing products - it would seem to be the obvious thing for them to do, although they could equally see Sketchup as a vehicle to broaden their product offering in disciplines they are yet to exploit.
                                      Mike
                                      A more up to date robust Sketchup would certainly be better than more features, particularly as the timing of the next update is so vague - sometime in 2013. The speed of Sketchup has never been a major concern for me, integration with other products in the workflow has, that includes compatibility with the hardware other software needs to run.
                                      Thank you all for your responses, they have given me a better idea of what is happening. Best regards. πŸ˜„
                                        @phillip said:
                                        Thomas
                                        I terms of marketing Google did very good for SketchUp - I agree. But in terms of developing the core application - they did badly.
                                          jason_maranto
                                          How true... I came along right after Google bought SketchUp and was enthusiastic about having such a well moneyed and powerful company behind the product... won't make that mistake again πŸ˜‰
                                          Best,
                                          Jason.
