    Correspondence of color names in Paint Bucket
    3 Posts 2 Posters 410 Views 2 Watching
    • lbsswuL Offline
      lbsswu
      Does anyone know the correspondence of color names in Paint Bucket and Color table?
      For example, I select a color "Color_A01" in Paint Bucket, is the color in the Color table https://developers.google.com/sketchup/docs/ourdoc/color?, like "AliceBlue".
      The "Color_A01" is select by someone else, I need to know the corresponding name in the table so that I can use it in my ruby code. Is there a corresponding list?
        I'm not sure that there is any correspondence between the external SKM file's RGB values and the built-in [OpenGL] colors.
        You can of course make new materials directly from from colors - like 'AliceBlue' - just by specifying a valid name as the material.
        You can also get any material's RGB color values in API code and from that you can compare it to the 'built-in' colors' RGB values.
        See the Material AND Color parts of the API docs...
        If you have a material already in the SKP why do you need to use a new 'color' based one at all ?
        • lbsswuL Offline
          lbsswu
          Hi, TIG. Sorry for my late thanks.
          Actually, other people im my group use two styles of colors, e.g.the external SKM file's colors and the built-in [OpenGL] colors. I want to integrate them.
