    THEA Render Question
    6 Posts 4 Posters 424 Views 4 Watching
      liam887
      Not sure if this is in the right section so Mods please dont be offended happy for you to move me. I did post it in Thea forum but thats usually slow to respond and I know most people here have used it.
      I have a very simple model and need to render it to look glossy, shiny, bubbly. Only problem is its a boring flat cube so this light doesn't play very nice with it.
      I just realized I have never had this problem before as I have never bothered to render anything this boring.
      I cant use a reflection map to jazz it up as I dont want reflections (neither does the client).
      Does anybody have any advice on how to improve it? I could fake it in PS but for once I actually want to learn how to do it RAW in THEA.
      Here is an image attached. The client wants it Magenta and from this angle but I can change the material texture etc.
      Cheers in advance
      Liam
      PS - I am not very good at render materials. I can make interesting models and also fake renders with my Wacom in Photoshop but this simple task has beaten me I am afraid. The best solution gets a copy of Wired magazine posted to their house. I will also throw in a Wired pencil...how about that. Wired pencils are very rare btw!
      PSS - If somebody in the THEA forum also posts a good answer you will both get magazines but I will have to only give you half a pencil each!
      VISIT MY ONLINE GALLERY
        You've sun enabled for the blue BG. Is this intentional?
        Put a studio hdr into reflection...
        suc-studio-1.zip
        to give the plastic some extra jazz.
          liam887
          [attachment=0:2air6n6m]<!-- ia0 -->suc-studio-1.zip<!-- ia0 -->[/attachment:2air6n6m]
          Wow where did you get that thing? Did you make it or can you buy them?
          It has made a difference already I will keep playing until it works.I will send you a magazine and a pencil!
            I made it so you are safe using it but search deviant art for a great set of studio hdr images.
            try rotating either the object or the reflection to get the reflections to hit the right spot.
            on the bottom left of thea is a properties tabs. Increase the ISO to 400 and the exposure to 250.
            • soloS Offline
              solo
              A quick test
              http://www.solos-art.com
              • N Offline
                notareal
                Used lighting makes the model flat. Like Rich said, I'd use some suitable studio HDR, like zbyg's HDRI packs 1-3.
                Also material do affect a lot. As model if fairly simple, you could try some sss material. If your model is sized 10-20 cm scale, you can use these 3D printing materials (just change color to your need and maybe extra coating layer if needed).
