    Extruding without turning the profile ???
    3 Posts 2 Posters 277 Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hello everybody,
      my script "extrude along path"
      TURNS the selected profile around along the path
      is there a script, which is able to draw an extruded profile in a continuous angle (like the original) ?
      so with a rectangle a continuous ramp would be drawn?
      example attached
      thanx stan
      02c-test extruder.zip
      • massimoM Offline
        massimo Moderator
        Hi stan, if you need something like the model attached use this plugin.
        Also I suggest to purge your models. You had something like 98 unused layers, 24 materials and 25 components. 😲 (from 4,4 Mb to 440 Kb)
        02c-test extruder.skp
          artmusicstudio
          hi,
          thank you very much, that is exactly, what i needed ! great! thanx again for helping!
          stan
