    Arc center point Plugin?
    13 Posts 8 Posters 2.4k Views 8 Watching
      Click Draw
      Hello,
      I will get models from other people that have arcs that I need the center point for. Are there any plugins for this where I can select the arc and then use the ruby to place the center point?
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • sdmitchS Offline
        sdmitch
        Try AddCtrPoint plugin on my blog.
        http://sdmitch.blogspot.com/
        • cottyC Offline
          cotty
          Or Exploded Arc Centerpoint Finder (Chris Fullmer)
          my SketchUp gallery
            mwm5053
            Or maybe this http://forums.sketchucation.com/viewtopic.php?t=18963
            you can also right click arc an context menu has find center.
            2011 iMac
            SU 2015 Pro, 2017 Make
            V2 Twilight
            macOS Sierra 10.12.5
              Click Draw
              Thanks guys!!! As always, the forum to the rescue....
              Cheers
              • pbacotP Offline
                Yes, I've seen this mentioned. I don't have that as my basic SU. Wonder why.
                • TIGT Online
                  'Arc-Center' part of the shipped_with_Sketchup scripts that need activating from Preference > Extensions before they'll appear in any menus etc...
                  • pbacotP Offline
                    Thanks TIG.
                    I looked at that before, but nothing there does that for me.
                    • TIGT Online
                      If you activate the Preferences > Extension > 'Ruby Script Examples' you get a right-click context-menu item "Point at Center"... but only IF you have an Arc/Circle already selected.
                      The advantage of using one of the other 'arc_center_point' tools is that activating 'Examples' also loads several other tools you might never need...
                      If you have an Exploded Arc then you'll need Chris Fullmer's tools to deduce where its center would have been...
                      • pbacotP Offline
                        TIG,
                        Thanks! Sorry I didn't actually try those, because the included scripts are listed and this one isn't mentioned.
                        Peter
                        • TIGT Online
                          I noticed that lack too 😒
                            Me too! Me too! I got a plugin! 😄
                            http://forums.sketchucation.com/viewtopic.php?t=30506
                            • sketch3d.deS Offline
                              sketch3d.de
                              Attached a stripped down version of only the "Point at Arc/Center" context menu command derived from the Ruby script examples of SU8 and condensed to one file.
                              Thus the function cannot be disabled/enabled via the "Preferences > Extensions" dialog, just drop to the "\Plugins" sub-folder, restart SU and you're gone.
                              If someone of the Ruby programming gurus here likes to enhance for the configuration via the extensions dialog, just go ahead.
                              [Update 12.05.14]Converted to an extension which now can be enabled/disabled via the Extensions dialog and saved in RBZ-Format sothat installation can be done via the Extensions dialog too.[/Update]
                              hth,
                              Norbert
                              RBZ archive
