    Best settings frosted glass
    renderpluginsextensions
    4 Posts 3 Posters 12.9k Views 3 Watching
      Rico91
      what is the best material setting for frosted glass.
      example of what i need. (i need the second one 'frosted glass light')
      http://1.s3.envato.com/files/1115783/preview.jpg
      [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
      • andybotA Offline
        andybot
        You can adjust your refraction glossiness until you get the amount you need. You could start at something like 0.6 (default is 1.0 for clear glass.)
        • V Offline
          valerostudio
          Dont forget to set your subdivs high on that refraction glossiness (30 or more). Render times will be a beast but the results are worth it.
          • andybotA Offline
            andybot
            πŸ‘
            the subdivs setting will control how smooth the frosted glass looks, the higher the number the smoother it looks (but at significant cost in render times)
