    Two doubts: component dimensions and align components
    6 Posts 3 Posters 450 Views 3 Watching
    • R
      rause
      Hello.
      It is my first message. I'm spanish, then sorry for my english πŸ˜„ I have two doubts:
      Are there any way to know the dimensions of a component or group? Withouth to use the measuring tool (T), some times doesn't works (specially with downloaded 3d objects).
      How do you align this?
      https://dl.dropbox.com/u/9738375/su_centrar.png
      Components and groups haven't inference lines?
      Thanks.
      • TIGT
        This tool http://forums.sketchucation.com/viewtopic.php?p=370385#p370385 will add guide-points around the object's 'bounds'. You can then use those to measure/align the objects, useful if they are made of odd shapes...
        [flash=720,540:395w7h1s]http://www.youtube.com/v/0rq6XX8fNXk[/flash:395w7h1s]
        • R
          rause
          Thanks so much TIG πŸ˜„ Very useful.
          One more thing...
          With this plugin, I can't align center groups/components.
          See my screenshot. How can I to align the cilinders group just in center of the rectangle, without drawing anything inside the group (like a line between the cilinders)?
          • TIGT
            No screen-shot ?
            There are some 'Align' tools available - look in the 'Plugins Index'.
            However, drawing some temporary lines outside*** of the group/component objects between appropriate guide-points, and then selecting those with the objects to be moved you can snap mid-point to mid-point etc to align them in various combinations...
            Simply erase the temporary lines after they are no longer needed.
            *** If these lines are needed frequently you could consider placing them inside an object's container to simplify selection...
            • Jean LemireJ
              Jean Lemire
              Hi folks.
              With some simple geometry, it can be done with native tools.
              Click in sequence on the scenes tabs of this SU file for ideas:
              Aligning cylinder and rectangle.skp
              • R
                rause
                @tig said:
                No screen-shot ?
                In the first post. The group of the cylinders inside the rectangle. My english is very bad, sorry πŸ˜•
                I'll search some plugin. Thanks TIG.
                Jean Lemire:
                Thanks for the explanation. I know this method. My doubt is about to align groups, like in my first post. It seems is necessary some plugin.
