    Joinning lines
    10 Posts 6 Posters 454 Views 6 Watching
      rumcajs
      Is it possible to join two lines? For example, I have a wall with a texture in which are "door". Not door really, just empty area. Now I would like to take top line of the "door" and to move it down to bottom area, so whole area looks like rectangle. But it is not because the bottom line is separated into two lines. So can I make one line from that who lines?
      • massimoM Offline
        massimo Moderator
        Not sure I understand what you mean. Anyway if you want to join two or more connected edges into a "polyline" you ca do it with native SU tools like the picture below or you can use this plugin.
          rumcajs
          Thanks. It works. Just it take me a lot of effort to zoom exactly to the joint.
          • mitcorbM Offline
            mitcorb
            Hi, massimo:
            You posted just ahead of me and you covered it well.
              ArCAD-UK
              Funny thing about the SU inference engine, it can sometimes find the end point etc quicker from a zoomed out view than than you can trying to zoom in and find it! 🤓
              • Jean LemireJ Offline
                Jean Lemire
                Hi folks.
                You can find endpoints easily if you can see them.
                Use the styles to show endpoints.
                Just ideas.
                Jean
                  rumcajs
                  @jean lemire said:
                  Hi folks.
                  Just ideas.
                  Jean
                  Where?
                  • ely862meE Offline
                    ely862me
                    Window/Styles-click on the house icon-select your current style(if you have more) -Click Edit -Check the box for Endpoints and write the amount that suits you(1-99) .
                    Enjoy !
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                      rumcajs
                      Thanks. Can I change also color of endpoints, but not change color of edges? Coz color of edges changed when I tried.
                      • ely862meE Offline
                        ely862me
                        Apparently they can be changed once you change the Color by the axis . They change once with the lines .
                        As far as I know !
                        Perhaps there are some plugin but I don't know one yet !
                        Take care !
