    Shapemagic-free-
    6 Posts 4 Posters 541 Views 4 Watching
    • micioneM
      micione
      Hi, report a free program very interesting. Easily create a lot of solid forms. Save in obj.
      http://www.shapemagic.com/
      • R
        Roger
        What do you use to convert OBJ to SU?
        http://www.azcreative.com
        • TIGT
          There is 'OBJimporter'... BUT an OBJ file from this app will almost certainly 'have issues'... you might need to import it into something else that can cope... then re-export as a compliant OBJ to move over into Sketchup...
          • R
            Roger
            Didn't you do a plugin called OBJ2SKP ?
            • micioneM
              micione
              TIG has just said.
              To import into SketchUp OBJ files from other programs I use "3D Object Converter" (not free). then from there save as obj, and import into SketchUp with "Fluidimporter".
              Other programs that can reprocess obj files are: MeshLab; netfabStudio.
              Regarding "shapemagic" you must save the file obj, unchecking the box UvMapped. (Could cause problems).
                From the same place maybe Road Maker
                can interest some people ? ๐Ÿ˜‰
                http://www.shapemagic.com/roadmaker/road7.JPG
