    Shapemagic-free-
    6 Posts 4 Posters 368 Views 4 Watching
    • micioneM Offline
      micione
      Hi, report a free program very interesting. Easily create a lot of solid forms. Save in obj.
      Lathe Magic and Shape Magic Home
      Shape Magic and Lathe Magic 3D Model Generators. Create designs for woodturning and for use in Bryce, Vue, Poser and other 3D programs.
      (www.shapemagic.com)
        Roger
        What do you use to convert OBJ to SU?
        http://www.azcreative.com
          There is 'OBJimporter'... BUT an OBJ file from this app will almost certainly 'have issues'... you might need to import it into something else that can cope... then re-export as a compliant OBJ to move over into Sketchup...
            Roger
            Didn't you do a plugin called OBJ2SKP ?
            • micioneM Offline
              micione
              TIG has just said.
              To import into SketchUp OBJ files from other programs I use "3D Object Converter" (not free). then from there save as obj, and import into SketchUp with "Fluidimporter".
              Other programs that can reprocess obj files are: MeshLab; netfabStudio.
              Regarding "shapemagic" you must save the file obj, unchecking the box UvMapped. (Could cause problems).
                From the same place maybe Road Maker
                can interest some people ? 😉
                http://www.shapemagic.com/roadmaker/road7.JPG
