    Purge All on Steroids
    4 Posts 3 Posters 1.1k Views 3 Watching
    • david_hD Offline
      david_h
      Is there a Plugin a la Purgeall that not only purges unused but ALL materials Used or Not in the model. I want to strip down easily a pretty complex model that has a lot of undesirable materials.
      Any thoughts?
      Thx, in advance
      D
        My 'Global_Material_Changer' http://forums.sketchucation.com/viewtopic.php?p=63629#p63629 let's your current selection's materials go from '<<ALL>>' to '<<Default>>'... so to change absolutely everything just switch everything on and select-all before processing]. A subsequent Purge of Materials will then remove the unused ones...
          Material Tools
          http://forums.sketchucation.com/viewtopic.php?t=17587
          • david_hD Offline
            david_h
            thanks guys. I'll check em out.
            D
